Too Much Draft
kubotamike
21
New Brunswick Canada
I recently had a new Pacific Energy Super Le install along with a 22-24' Ventis Stainless Chimney and 50" of ICC double walled stove pipe.
Ever since the install I've been unable to control the fire as it has too much draft .
Last week the company who installed it did a draft test and it was at .10 on their gauge so they installed an ICC key Damper .
Since the damper was installed it has slightly made it better but even with the damper closed and the stove draft shut down I'm still not able control the fire and get secondary burns. Even when I light the stove there is so much pull it will close the stove door I have to hold it open . I've checked the door seal and the ash dump seal and they are both okay.
Any Idea's on how to tame this beast down !
Did you see it?
That is the most "open" damper that I've ever seen...better than nothing, but just barely!
I think you need to either install some fender washers over those holes (washer on each side, bolt through) or since there are so many large holes, I think I'd just get some stainless sheet metal, cut out discs the same size as the damper blade, then bolt through.
I doubt the installer will be willing to do that, so hopefully you can diy it.
If not, then you need to find a different brand damper to put in there that is not so "see through"
[Hearth.com] Too Much Draft
Yes, that's a pretty leaky damper. There are other dampers that close off more air. You never want 100% closure, that would be dangerous, but 75% is a good initial target. This is a typical aftermarket pipe damper.
Yes I seen that there are large holes and wondered about that . If I cut a piece of 16 gauge steel large enough to cover the ICC side would that be enough ? And either bolt it or tack weld .
Try that for a start.
I might be able to take off the top 2' of chimney, not sure if it would help but can't see how it would hurt .
Be sure that the chimney still meets the 10-3-2 rule requirements. If so, yes, removing 2 ft can make a difference.
Some also fit close to the outside of the pipe. If you look at the size of the air intake on the stove, it can run with a pretty small exhaust as long as the door isn’t open.
  • [Hearth.com] Too Much Draft
Don’t fully trust gauges. They are often wrong.
You should be fine trying to keep your stovetop 6-650F. Start turning the air down long before the stove gets to that temp. Watch the health of the flame and secondaries to figure out when to start turning it down.
That's part of the problem, I can't get secondary burns . I have to start turning down the draft as soon as it the reload takes off or It will get out of control quite fast. I just loaded in 3 smaller splits and I was a little slow turning it down and it was an inferno in no time . I see my temps in the 550- 600 range .
First step, tame the draft by blocking part of the damper.
You should have lots of secondaries at those temps. Have you tested your wood for moisture content? Maybe moisture is cooling the secondary burn?
I'm wondering if the draft is so strong that the wood gases are not staying resident in the firebox long enough for a visible secondary burn. If so, the secondary burn may be happening above the baffle. 🫨
Does this unit lend itself to having the air intake(s) partially blocked off? At least long enough to see if it helps.
To the OP, did you test the wood in the middle,on a freshly exposed face right after resplitting it?
Testing on the outside and/or ends is meaningless
Yes, in the least, the boost air port can be blocked with a magnet to see if that helps.
Reactions: brenndatomu
I know that made a big difference on my old VZ stove...my chimney is only 17' and the VZ still wanted to run away on me! With good dry wood it didn't need any boost air!
I tested the wood with a few fresh splits and it's dry , it's all maple that was sun and wind dried for 15 months before putting in my woodshed. I did try blocking of the air boost that comes in the front of the stove but it didn't really help.
Leave the boost air blocked and try convering the ICC part of the damper with a stainless steel patch. This can be pop-riveted on if stainless pop rivets are used.
Installer was back today and removed 18" of chimney put a restricter plate 6" to 4 1/2" on top of flu at cap and changed the stove door. We also put in a pipe Thermometer . With 3 smaller splits the pipe Temp spiked at 900 then stated back down . I really don't see much of a difference in it yet but have only put wood in once . Is 900 degrees a little excessive ?
Sounds like good progress.
It's within tolerance. If the air is turned down quicker, then the startup flue temp can be better controlled to peak around 700º. This is where a digital thermometer really helps. An analog probe thermometer takes time to react. There's a lag of about a minute. A digital thermometer with a probe provides close to real-time temps. It's made a big difference for me in avoiding these startup spikes in temperature.
Have you had a chance to look at this thread? It illustrates the difference between analog and digital readings.
The key is turning down the air fairly aggressively, without fully squelching the flames. FWIW, 900º is still within the pipe tolerance, especially for a short time. I think all of us have had that temp in the flue at some point. I certainly have spaced out turning down the stove and seen it at that temp or even a bit higher. It's easy to get distracted when waiting for the fire to gain strength. Now I carry a timer and have an alarm set on the digital probe.
Note that of all the temperature readings, the stove top is the slowest to react.
