Track saw recommendations?
EbS-P
7,626
SE North Carolina
Hi all,
I have several cabinets to make. One will be a custom chuck box for the new van and several pull out trays for the check box cooler etc.
I am debating buying a track saw. I have a shopsmith. And it can do ok for breaking down sheets but the table is a bit small.
Do you have any recommendations on track saws? I could get a long track for my circular saw….
When I was doing custom woodworking I had a festool system. Pricey and it used their saw which I found lacking. The founder of my company got into woodworking and asked me for one and I found True Track . Nice US system that was a lot cheaper. Good system. Track is good and it has a sled that rides it to mount your saw to.
After using a friends Festool track saw I decided I needed to own one. Didn't want to spend that much, so I bought a Wen saw. Not high end but more than adequate for my needs. Be aware the track is sold separately, it's not included.
Reactions: EbS-P
I have a Bosch saw and 2 tracks bought 3 years ago . This one was a heavily discounted sale price at the time and had to make sure track was included in the price . I am a trim carpenter but even as a business expense I want to save money.
Wish I had got one sooner . Track joins quickly and breaking down plywood sheets much easier than table saw .
Last project with it was to rip down stiles and rails from old pine doors to salvage the clear pine to make windows .
Reactions: EbS-P
The MilesCraft track system has a great reputation. You use it with just about any circular saw.
I've built several for my saws over the years. This seems like a great DIY one but I'd use Masonite for the based instead of plywood.
I've got the Kreg Accu-Cut and run it with my Dewalt circular saw and a 72 tooth blade. It works well for what I need to do with it, and my dewalt saw has a sturdy aluminum base to fix to the Kreg sled.
Reactions: EbS-P
I just got the Kreg Accu-Cut also. I'm a bit disappointed in the quality and the slop between the track and saw mount but I found a work-around.
The Milescraft would not work with the sidewinder saw that I wanted to use.
