x2Looks alot like bitternut hickory, tight diamond pattern in the bark. the pignut i am burning this year needs more air then the rest(oak,ash). i does burn hotter IMO than oak. all were cut at same time and stacked together. i think it may just be the nature of the super dense species(hickory,locust,osage). try feeding it more air to get a complete burn, but watch your temps!
Yes-the adage of hickory being a superior wood goes out the window when it comes to bitternut, in my experience, I would rather burn tulip poplar. I have 1/3 cord of butternut I am currently mixing in. It tests at 15-17% moisture and still sits in a chunk at the end of a burn. Has nothing to do with an inaccurate moisture meter either.Pignut hickory..or bitternut whatever ya wanna call it !
Good points. It looks like the splits are from a smaller branch, so maybe the darker heartwood wasn't developed yet. But yeah, I see what you're saying about the visible medullary rays like you would see in Maple. I don't think I've ever seen that in Hickory... We need mo' better pics!I'll take the abuse and say I don't see hickory, 3 things, bark isn't quite right, heartwood should be darker and in your last picture I see vertical lines in the grain thats found in maple so that's my guess
Looks like hickory to me it just won't burn up as clean as most wood. Great heat though.This wood leaves a lot of chunks compared to the oak I've burned. Any help is appreciated.
Sent from my SM-G900R4 using Tapatalk
Was thinking just the opposite. Those bacon strip flakes sure look like a maturing shagbark before it gets really shaggy or the slightly less flaky mature bark of the shellbark hickory. If that's the case I do agree it may not be seasoned or there may be a stove issue as both of those burn well once dry.Even looks more like maple than hickory in this pic
You must have a good monitor...I can barely see those on mine.I still see these in the latesest picture on the bottom split
