Tree ID
Slimdusty
258
Washington State
Need some help with this yard tree. I’m not familiar with it, not native to this area as far as I know.
[Hearth.com] Tree ID [Hearth.com] Tree ID [Hearth.com] Tree ID
At first I was guessing something in the hickory family, maybe pignut? But on the west coast, maybe Chinese pistache , chinaberry? Does it have blossoms in the spring?
Does the foliage turn brilliant orange in the fall?
Best tool I've found is if you have a phone use Google Lens, do the leaves and the bark.
I do and have used google lens, it’s pretty good although not always, as in this case it shows the bark as oak and the leaves as ash. I am no ash expert but it definitely looks different than our local Oregon Ash.
No blossoms to my knowledge and in the fall I would say normal fall color foliage, not a brilliant orange. Also does not produce nuts of any sort.
I'm going to guess Elm. Not sure which kind though. Are the leaves saw toothed? hard to see in the pics.
Maybe not Elm, the leaves are not staggered off the stem.
My Google lense based on the leaves gave Chinese pistachio or Arizona walnut
It is merely AI and I'm no west coast connoisseur....
But suggestions is where one starts...
Very small saw tooth edges on the leaves, will try to get a better photo today. I looked up chinese pistache tree, and it has similarities but doesn’t seem quite right.
I don’t think it’s a native tree. Opposite leaves and compound leaves are usually the territory of Ash. All of the leaves I see have more than 6 leaflets while ash have 6.
But what it is, no idea.
Manchurian Ash (Olive Family), Possibly Black Ash
Reactions: Slimdusty
The combination of the pictures (but mostly the leaves) confirm a form of ash, since you are washington most likely oregon ash or was a planted non native green ash (since that is what it really looks like tbh). Im from WI and we are flooded with ash trees, unfortunately most are dying from the EAB
When Google Lens is throwing random guesses, i'd honestly just grab a photo and bring it to a local nursery or the extension office — they deal with this stuff all the time and usually nail it pretty quick if it's something established in your area. saves a lot of back and forth.
Another vote for ash, depending on the variety they have 5-11 leafs, pretty good firewood and easy to split.
Take one picture of the leaves and one of the bark. Send one of those pictures to the AI on your phone. Ask the question as follows "Identify the tree found in (enter zip code here) this photo". Note what it says.
Then do the exact same thing with the other picture. If your AI returns the same answer for both, and it usually does if the photo is clear enough, you have your tree ID.
I've found this method to be exceptionally accurate with trees, wildflowers, wild mushrooms, houseplants... pretty much anything botanical. Will it know the correct answer as to what variety of a particular vegetable you show it? Probably not, with all the hybridizing. But it's great on the other stuff. Try it!
