tried out some ECO logs
SmokeyCity
428
Western Pa
Saw ECO BRICKS at Tractor Supply. Came in bundles of 8 and each log was shaped like a giant bar of soap.
After reading about them online I could not resist an experiment and decided to test them out for myself. They are denser than hardwood and more dry than most seasoned wood. They were easy to light and they burned with very little air being required (once they were going good). They produced nice secondaries and a lot of heat. Because they are so dry and require so little air to burn, they burned noticeably longer than would a load of similar sized split.
I bought several packs and have about 3 dozen bricks left. The plan is to use them as sort of "fire-starters on steroids" because they ignite so easily and of course double as fuel once burning.
They are not as economical as cordwood but I have not done any burn time tests to come up with an approximate bang for buck analysis.
  • [Hearth.com] tried out some ECO logs
Sounds like they might be nice for long burns. There are some cold nights coming some time this winter, I guess.
I use a couple instead of kindling to get the fire started and also if I need a long burn. They burn long and hot. I bought a ton last September on sale. I store them in the garage, which is particularly handy if it's too snowy or stormy to get to the wood pile. Which hasn't been a problem so far this year.
I use them on colder days/nights for longer burns (like yesterday when it was in the 20's dropping to the teens). They burn longer and seemingly hotter than the cordwood I have. I'll pack 3-4 on "warmer" (high 20's) days or 4-5 on colder days/nights (low 20's and below)inside of two splits at about 6am and still have coals to relight off of at 6pm, and a warm Cottage to come home to.
I found they didnt burn too well unless the stove was already warmed up. Not ruling out user error, just my experience.
TSC had them on sale (one "case") for 2.50 or something crazy earlier in the year, was too cheap to not try it out.
