Simonkenton
Regarding my non ventilated wood shed:
The walls are white pine. The floor is pt Southern Yellow Pine 2x6s.
No mold grows in there, even when just loaded up with green wood. But it does get pretty humid. When you fill it up with green wood, at night you get condensation on the steel ceiling, and it drips onto the floor. This goes on for about a month. There might be a quart or two of water on the floor, and on the wood pile in the morning, a week after you have loaded it up with green wood. However, with the door shut, that will all evaporate by 11 am. And that water vapor passes right through the walls and floor. Floor a minimum of 16 inches above the ground.
If I am at home on a nice sunny day, right after I have loaded it up with green wood, I will wait until about 5 pm, for it to get really warm in there. Then I will open door to let the hyper humid air out. I will leave it open until dark.
When I was designing and building the wood shed, the idea was to make it non ventilated, and to rely on heat from the sun, and the ability of water vapor to pass through non painted and non stained wood.
I was designing a fan for the woodshed. Put a solar powered vent fan up high in the gable and a couple of intake vents down low. It would be good to blow out that warm humid air, there for about a month when you have just loaded the shed with green wood.
However the shed works fine as is, and to add an electric fan would be complicated. So I never installed the fan. Simpler is better than complicated.
We have had a cold, snowy winter and I have used up the entire left side of the wood shed, so it is time to replenish it. I will do a photo essay on it, going to fill it up with black walnut this time.
