Greetings,
I have an 8 year old Jotul 3 CB. I am unable to control the hot burn with the primary air control slide. This problem has started all of a sudden. As I stated, I am unable to get a slow steady burn. The flames are high and are collecting/swirling up around the baffle which is uncharacteristic for this stove. I checked the load door gasket and ash door gasket. The load door gasket was good and tight but I did replace ash door gasket. Checked the casting with a light and could not find any cracks. The primary air control slide is opening and closing as it should. Any info concerning this hot burn problem would be appreciated.
Thank......Maplewoods
