used stove. blows dog smell... help
Febreze actually chemically eliminates odors, it doesn't just mask them with a pretty scent. Maybe try removing the room blower and spray some into convection air path.
Reactions: jeremygrimm
Something has to be causing the odors: dead mice, mice nest, cat or dog pee, mold, burned motor, etc.. I would dig deeper. And for me I'd avoid using a Chemical Air Freshener such as Febreze.
Check the convection blower for matted hair sticking to the cage.
Reactions: bobdog2o02
Remove and clean the convection blower motor and assembly. Use your compressor if you have one. Clean the squirrel cage with a quality cleaner. Lastly, thoroughly vacuum the convection duct work. Use pipe cleaners if need be. Also, clean the stove's back side. That is the area the convection blower draws it's air from.
Put into your signature what stove your trying to salvage. Some stoves have a fiberglass heat barrier and will need to have a complete tare down and scrub to try an abate the odor
The last owner had dogs. Lots of dogs. That's why it smells. Now it's in my house with no dogs.
I was going to tell you to have your dog move away from in front of the stove, but... nevermind. ;lol
After cleaning and removing any dead mice and pet hair I would spray with Lysol IC spray. Wet all the convection passages and let dry. Then do it again. You should ventilate the room and not use the room until clear of the fumes. That should take care of any bio funk living in the stove. This works on car air conditioning vents too if you spray it in the intake near the wipers. Use caution and follow the directions. This is a powerful disinfectant used in hospitals and schools for hard surface decontamination.
This could turn into a humorous thread...........
Ever try burning Piss Elm? Someone put in a work bench in a shop I had and every time the weather got humid it got real rank.
No but I have burned three different pellet brands in a basket in a wood stove. And if any of them just smelled like what comes out of the South end of a dog, it would be an improvement.
Reactions: Ashful
You get Indeck pellets out there too? :)They smell like swamp gas, haven't had the pleasure of trying to smell em burning.
Smelling any burning pellet I have a hard time believing that they are made of wood.
I bought some blended pellets and they smell very pleasant burning. Good right out of the bag too and that's good as the Elena has a open hopper.
Woof on two accounts.
Had to laugh at a guy that was picking up pellets at the store when he was complaining about his Englander needing another auger motor as was its second in 14 years and he paid a whole $700 for it new as a closeout from Lowes. Would be the third item to be replaced:)
