Hello, I am new here and new to pellet stoves in general and would really appreciate any help I could get. I’m incredibly frustrated. Just purchased a Summer’s Heat from England’s Stove Model # 55-SHPCB120, from Lowe’s. Set it up with a kit. I think I have everything set up correctly according to the video that came with it, the manual, and the kit instructions? I performed a dry run and it worked fine. Then trying to start it the first time it said False Start and so I reset it like it says to, then it fired up again and now everytime it will run for about 10 minutes but then gives the Vacuum Loss Shutting Down error. My piping is direct horizontal out of the back then vertical 3’, but as directed. I taped all the joints just incase it was getting no vacuum, didn’t help. The manual says about using silicon sealing on the piping? How important is this for this model and would the sealing tape be as good? I did not do that, but taped it? The door passes the dollar bill seal test accept by the hinges where the seal actually meets together, it is a little looser, in the video it shows the seal came together by the handle. Could that cause a problem? I checked the vacuum hose and there was only a clamp on one end so I put one on the other end that didn’t help. I just tried to blow through the hose to make sure it is clear and I’m gonna try it again and see if that helped. Any advice/suggestions/experience with the Loss of Vacuum error on a brand new pellet stove? Incredibly frustrating.
