Hi All.
I bought a brand new VC Defiant II W/S about three years ago. I have a completely vertical flue pipe of 8" diameter that measures about 10 ft in length from the top of the stove to cap above roof, so based on all I've seen the draft should be adequate.
I have a flue pipe temp gauge just above the stove on the oval to round adapter just below the round pipe connection.
I only use SEASONED Oak/hickory firewood that's DRY!...
Since new, When I fire it up, I watch the temp guage until I hit about 500-600
then move the left hand damper lever to the "catalyst mode." (closing the bypass damper technically) I usually keep the temperature lever to max (it's on the right and max is CW or pull handle toward the front of the stove). The stove puts out heat, but the flue temperature gauge will drop down to the 250-350
range and NEVER go into the "catalyst hi temp burn" mode that I see on the other posts. Even if I let it go over 700 then switch over, it still drops to this temperature range.
It's almost as if the thermostat controlling combustion air damper (primary air valve) is choking the stove down. I can LOWER the temperature further by turning this temperature lever CCW (toward the rear).
I've checked the catalyst frequently and it is never "caked up" or "plugged up." It will have slight dust on it.
What's worse is my flue pipe gets a lot of creosote and my exhaust out the stack is far more smokey than the old fashioned (non catalyst) Franklin stove I took out.
The dealer "Heckler Hearth" in Troy MO, basically said. "Gee we don't know how to help it shouldn't do that."
I have the parts blow up diagram that shows this temperature control unit, but it doesn't really show where it is on the stove.
I saw photos of the unit INSIDE the stove on the VC Defiant forum, but WHERE do I gain access to it and where is it located?
Am I on the right track that likely the temp control thermostat is out of adjustment (from the factory I might add)?
What is the procedure to adjust it?
Should I be getting this much smoke and creosote?
Shouldn't I be getting flue temps in the 500-600
range in catalyst mode?
Can anybody help me sort this stove's operation out?
A very frustrated VC Defiant II owner.
range and NEVER go into the "catalyst hi temp burn" mode that I see on the other posts. Even if I let it go over 700 then switch over, it still drops to this temperature range.It's almost as if the thermostat controlling combustion air damper (primary air valve) is choking the stove down. I can LOWER the temperature further by turning this temperature lever CCW (toward the rear).
range in catalyst mode?Can anybody help me sort this stove's operation out?
![[Hearth.com] VC Defiant II Thermostat issues [Hearth.com] VC Defiant II Thermostat issues](https://www.hearth.com/talk/data/attachments/216/216121-27e40e49bb99dd6f9e146bcf1f0504f7.jpg?hash=-40zY--cr8)
