Hi Everyone,
I am most likely going with the Castile and installing it in my family room in a walk out basement. It will be a corner installation.
There is a 3.5 foot stem wall there with another 5.5' to the ceiling. The grade behind the stem wall is probably about 6-8" below it.
I will have to run the venting pipe out of the stove, up 5.5-6' or so and through the wall.
Being that I live at 8,000' I will be using 4" venting pipe.
Questions
1. Will the 5.5'-6' vertical run inside the house be enough for adequate draft so that if the power goes out the smoke will exit out the vent? Does it matter if the vertical venting run is inside or outside the house?
2. How far away from the house should I put the venting cap at the end of the run so that I will not get soot on the side of my house?
3. Is there any way to put in a cold air intake vent that will look good aesthetically? The intake vent would have to run up and over the 3.5' stem fall before going out the side of the house. I would like to run a cold air intake but if there isn't any way to do it so it looks OK, I will probably not do it.
Maybe there is some type of system where I can use a larger pipe, say 6", where the intake is combined inside it (seperate from the venting section of course but looks like one pipe) This would also allow the intake air to be heated before it gets to the stove.
Thanks
Questions
Thanks
