Vermont Castings Intrepid 1969
whalefish
15
Oregon
I've been looking for a small, simple used wood stove as supplemental heat for a portion of our house, to go in an existing hearth. Found this one for $600, seems to be in good condition, is this a decent stove? I know the newer models that had the Cat are spendy to maintain but I'm pretty sure this one is a simple baffle system. Should I get it? Comes with the original screen, a kettle, And 6' of pipe.
Great stove, good deal if in very good condition. Examine closely!
What should I look for? Its still installed so I was going to fire it up and see about air flow, smoke leakage, cracks in the stove or warpage. There's a little rust on the top where they had a kettle.
You‘ve listed several things to check for, especially cracks. Check operation of air intake thermostat and secondary burn baffle. Hope it checks out and works well for you!
Mostly check for cracks and warpage, and function of the damper and intake thermostat/flapper. the older VC stoves are super easy to rebuild, so I wouldn’t get really worried about having to. Gaskets are no problem, but beware of stoves that have been run with bad gaskets, it is indicative of someone being careless and that leads to damage. As for checking draft, that is more indicative of the chimney it is attached to , so really isn’t going to tell you much. Good luck, and enjoy it.
