If the AC units are oversized for the area, they will not run enough to dehumidify the air. BTDT. You could try running one less AC for a day or two and see if the humidity changes. It sounds to me like you have too much cooling capacity.
Agreed: high humidity at 74 can feel warmer than a dry 80.
We only have 1 window unit cooling about 900 sq ft. If you count the whole house
It is in the only "normal" window we have as the rest are all crank out windows. It is in my husbands collection room in the window facing the bedroom, we keep the door open obviously and have a pedestal fan in the doorway to help push the air around upstairs. Downstairs is all stone so its usually cooler anyway. We've been here 10 years with the same set up, first year we have all this moisture! I threatened to fire up the stove tonight just to dry the place out
