hansenjw
In the article, the third point is to not reload on top of coals. What is the alternative? Is this why people take the coals to the front (or back?) when reloading?
I took that to mean use kindling to get get a fast fire and not wait for the the coals to light the big splits. I use 2-3 pieces bottom and top on a reload.In the article, the third point is to not reload on top of coals. What is the alternative? Is this why people take the coals to the front (or back?) when reloading?
I haven't read this yet. I am in the spring time chores here, we are having enough melt activity to have my undivided attention. I will fool with this autumn 2022. I have, in the past, been using a lot less than 3-5 pounds of kindling.
I do have a scale and I am going to fool with weighed amounts of kindling and a stop watch, but it will be Oct 22 before I have data.
www.hearth.com
@stoveliker I do remember asking that. With 14 % MC fuel and a handful of kindling, even a hand full of shavings made with an old hand plane, I can have a box load of full sized fuel pushing 1000dF flue gas temp with the combustor probe not even a third of the way up the inactive zone, from there I -have been- riding the air control valve to limit the flue gas temp to 1000dF while waiting on the combustor to heat up.
I have been fooling here in the spring shoulder a little bit with taking the loading door to just cracked open sooner and loading door latched closed sooner. Now that I am in the melt, or spring thaw, my RH near the ground is near 100% and my previously dry as a bone fuel is sucking up every water molecule that gets within fifteen feet.
One thing I will do this summer, Lord willing, is get some of the small sacks from fast food joints, the ones sized for one burger and one order of fries, to see how much those weigh, average, loaded up with wood chips. Besides handplanes, I have an electric jointer and an electric planer. That should be enough paper and wood shavings to get from cold stove to a bunch of kindling on fire in a big hurry.
What I will be looking to do is a fast/legal cold start with enough remaining fuel to run in active for, I want two hours. The way the regulation is written, whether or not cold start time is part of one hour of stove operation is disputable. A citizen with some sense would argue that smoke coming out of the chimney during a cold start clearly indicates the stove is in operation, but an expensive government lawyer might could make a convincing argument to the contrary to an expensive government judge.
Now that @BKVP has given me 5# of kindling to play with, and both @bholler and @begreen have signed off on 2000 (intermittent) flue gas temps I will be "doing science" this fall.
With 5 pounds of kindling and 2000dF stack temp, I can probably get my combustor lit off in under 20 minutes, at least with fuel at 14-16% MC. I want enough fuel left in the firebox for the cat to run engaged for two hours so the lawyer in the fancy suit can pound salt trying to argue I did a cold start and a hot reload in the same 'hour of operation.'
I need to find some fuel near 20%MC this year so I can fiddle with cold starts on that too. 20% just doesn't light off the way 14% fuel does.
I have experimented a whole lot with top down for lighting off my burn pit, maybe 2 dozen times per year. Because there's no chimney, and because a very large fraction of what I'm burning is green yard waste (shrub trimmings, tree trimmings, pulled flowers, etc.), and because the dominant wind and slope of the hill into which it is set naturally sends that choking-thick smoke straight toward the one neighbor who prefers open windows to air conditioning, I am very sensitive to the amount of smoke I make there. I have found the top down is always the best way to reduce the amount of smoke I'm making.My eyes show me, my top down starts with very little smoke and very fast start of secondary flames.
My God Poindexter, how long do you normally wait before closing that bypass? I'm not pulling any heroic feats, and I am pretty certain that my red oak stacked uncovered for three years is no where near 14%-16%, but I'm easily closing the bypass at 20 minutes with nothing but a quarter of a SuperCedar and one 18-inch 2x4 split in half over it, on full loads of this semi-dry oak. Why do you have to go to such extreme measures for this?With 5 pounds of kindling and 2000dF stack temp, I can probably get my combustor lit off in under 20 minutes, at least with fuel at 14-16% MC. I want enough fuel left in the firebox for the cat to run engaged for two hours so the lawyer in the fancy suit can pound salt trying to argue I did a cold start and a hot reload in the same 'hour of operation.'
Yes. Poindexter's a smart guy, so he surely has good reasons for what he's doing, but I've never had a failed light-off at any flue probe > 600F, despite the reading on the cat probe.Please forgive my ignorance, but at 1000f flue temps would the catalyst not be hot enough to be lit? I know you say the combustor probe is not active, but is this because of the delay in the analog gauge? Could a digital probe be fitted to shorten the response time?
He's got a few things mixed up. The EPA emission standard for crib fuel (M28R) is not 2.5, it is 2.0 gr/h. The 2.5 gr/h standards is for cord wood testing, which is an ATM granted by EPA, based upon ASTM3053. Also, it is not necessarily 2" x 4"'s in M28R. Depending upon FBV, you could wind up with an entire load of 4" x 4".This letter was posted on the Alliance for Green Heat's FB page. I thought it was worth sharing here. It brings up very good points. It's often not the stoves, but the fuel, draft, and how the stoves are run.
Letter: Ways to clean up wood burning
The trouble is, laboratory testing and real world operation are two different situationswww.cowichanvalleycitizen.com
And of course, stack temps are highly variable depending upon technology of the stove itself.They shouldn't be running that hot at all normally. 900 is the absolute top of what I like to see. Typical cruising temps are 450 or 500 internal temps which normally keeps you just above the condensation point at the top of the chimney. If the chimney is really well insulated you can run lower. If it's exterior clay or an air cooled chimney possibly a bit higher. It doesn't matter what stove it is those are the temps required to avoid creosote buildup. But no 600 to 900 is not stressing any of the metal excessively. Just wasting heat
So some very loose data exits on fuel loading orientation and how it effects emissions. A representative from a state agency has been loading fuel in multiple stoves. Baseline data was gathered based upon loading per the Owners/Operators manuals that came with the stoves. Thus far, EW loading has had the highest level of PM, followed by NS loading. In fact, the cleanest across all stoves used was cross stacking layers of fuel.For me a good top down fire is 1/4 to 1/3 of the firebox full clear to the top of kindling. At a small fire starter light close the door. Reload in 2-6 hours.
Absolutely think top down is cleaner but have no data. You can get the secondary combustion rolling in 5 minutes. No the stove is not up to temp yet on a cold start but it gets there quickly. On a reload I always start with 3 pieces of kindling on the coals and another two right on top to kick that secondary combustion off ASAP.
My first thought on your picture was there is not enough wood and kindling in that load. Is getting warm out so I understand if that a smaller load but the fewer times you add wood the less smoke goes out the stack unburned.
All good here, but it also is highly dependent upon the technology of the appliance. It's far easier (I mean to say quicker) to get to 550F than 1150F.I believe that I read that @Poindexter uses a few pounds (3 or 5) of kindling to get up to (cat) temperature quickly. I don't use that much either (and can get my cat engaged in 5-10 minutes -- I know cat temps are different than secondary burn temps, and thus a comparison with the discussion here is not very meaningful but: )
I think a lot of this depends on ones definition of kindling, ones flue set up, ones stove, and the dryness of wood and kindling (and the weather, tightness of the home etc etc).
It's nevertheless good to read how others do things well. Try things out for yourself, and stick with what has the best results in your situation.
They have enforcement officers driving around issuing NOV's (notice of violation) for opacity violations. Fairbanks residents have to get up to temp quickly and do so with as little smoke as possible. I'll bet you there are more Ringelman charts in FNSB than the rest of the USA! And for all those with bypass operations in their stoves, that also employ a combustor, if your fuel is well seasoned (14%-24%) you can close the bypass and see a more rapid increase to "active". I know this because I am finally (thank the Lord above) out of hardwoods and now into my 5 year old Tamarack! We tested a bunch of my fuel from home here in the lab. Using 2" probes, it ranges between 9%-10% MC.My God Poindexter, how long do you normally wait before closing that bypass? I'm not pulling any heroic feats, and I am pretty certain that my red oak stacked uncovered for three years is no where near 14%-16%, but I'm easily closing the bypass at 20 minutes with nothing but a quarter of a SuperCedar and one 18-inch 2x4 split in half over it, on full loads of this semi-dry oak. Why do you have to go to such extreme measures for this?
If the chimney hits 600F, I close the bypass, no matter what the stupid combustor probe reads. It's usually glowing within 10-20 seconds, easily indicating 1000F+, even though that nearly-useless (for startup) cat probe is still in the middle of the "Inactive" region.
Like I said before, "Poindexter's a smart guy, so he surely has good reasons for what he's doing." I have to admit, it's probably been more than 5 years since I intentionally looked up at my chimney to see if smoke is coming out of it. Sometimes I notice it when I'm outside, and most of the time it's clear or nearly so, but I'm sure it's not in the early part of a burn cycle, when I'm still indoors getting dressed and waiting out the 20 minutes on high after closing that bypass.Having a glowing engaged combustor does not immediately a clean plume make.
Boy that would be nearly impossible. Designated by EPA as serious nonattainment, brings a host of serious consequences. In addition to the opacity regulation, Alaska Department of Environmental Conservation (ADEC) has also put into place, an approved by EPA, many new requirements. Purchasers of wood or pellet heaters must register their appliance at the time of purchase. Wood sellers must be licensed and have the wood tested in order to sell it. The sellers themselves must be registered with the state. Any wood or pellet stove more than 25 years of age cannot be used. Non EPA certified wood heaters must be removed at the time of sale of the property. So if you purchased, in 2014 or earlier, a legal to sell/purchase fireplace, had $20,000 in stone work done, with a total investment of say $40,000, it must be removed at the time of sale.Like I said before, "Poindexter's a smart guy, so he surely has good reasons for what he's doing." I have to admit, it's probably been more than 5 years since I intentionally looked up at my chimney to see if smoke is coming out of it. Sometimes I notice it when I'm outside, and most of the time it's clear or nearly so, but I'm sure it's not in the early part of a burn cycle, when I'm still indoors getting dressed and waiting out the 20 minutes on high after closing that bypass.
But you live in a place with different rules, and I suppose they're rules that could come to most of us someday, so this is good information to log for future use.
Any chance of getting involved with the municipal government, and getting the regulation modified? Is clear plume really the best measure against the problem they're trying to manage, or just the easiest thing to police?
It's unlikely that the rest of the country will be as extreme. They are not driving the rules for everyone. AK and NYS pointed out flaws in the testing, but not the stoves. Fairbank's rules do not apply to the rest of the country. You are mixing up regional rules (not EPA) with stove requirements.
Still, there are many parts of the country that have the same geographical constraints and are prone to temperature inversions. Clean burning stoves help make a dent in emission while using less wood. More complete combustion also means fewer gases emitted, including CO2.
