get that puppy stacked
That's like standing on top of a pile of Gold......nice, nice nice!
Nice work!! Extra kudos for doing it in that kind of weather! Feels good, don't it?
You're a better man than I am
Nice get, your majesty! I would work that hard to add to my Hedge stash....
There is but I haven't hit a big score so far. Several "almost, but no cigar." I'm sitting on a grand total of 1/4 cord...In your location there ought to be plenty Woody.
Nice. I have some of that work to do too. Two weekends ago, I hand split 12 massive rounds that I had into manageable chunks (they were 350 - 450 lbs each and I hand split them into 70 - 100 lb chunks). Had to use sledge and wedge in 90 degree heat. That is hard work.
Probably will finish splitting those chunks into firewood and stacking this weekend.
The fun continues.....
It was cut 15 - 16" long.That's some big chit. What flavor of wood? What length is is cut to?
Ten miles one way is about my limit...you're out of range by several miles. Cut, split and stack it and get six years ahead; No reason to stop now! I try to avoid even ten miles unless it's some great wood that doesn't fall down often in our woods....White Oak, Shagbark, Pignut. No Hedge or BL on the place, although both are nearby. I'll go after lesser woods if they are really easy pickins or I need some quick-dry for someone. Can be hard to get to some of the stuff here, especially now when the brush is in full bloom and I can't see where I need to go with the quad as well as when the leaves fall.I've got two big Hedge trees the wife wants out. They are blocking her view of the pond from the house. If you were a hair closer you'd be welcome to come get em.
View attachment 135559 View attachment 135560
I don't have a pile to stand on, but my small stash is almost set. I have one more face cord to stack and the uglies to bin. Too bad most of this won't be ready til winter 15-16.
White oak, tree was still fairly green.
It wasn't far into the woods on a property and I was asked to clean it up. The tree had a big fork. Above the fork the rounds were 22" and then got smaller as you went up the tree. The fork measured at 51" and I left it in the woods (it was one big knotty chunk that I thought would be unsplittable). I know that to be true since a 16 ton hydraulic won't go through the chunks from below the fork. Below the fork was between 30 and 40". We tried pulling them out of the woods with my tractor and boom pole, and the bigger ones were heavy enough to pick the front of the tractor up if you chained them to the end of the boom pole. So I split them the old fashioned way right there in the woods.
What flavors do you have in the stacks? Any fast seasoning varieties? What are you planning to burn this winter? Most of my heat this year is going to come from 2 year Shingle Oak and some petrified Hedge that came out of my ditch banks last summer. By petrified I mean feels like granite and rings like a bell when you knock 2 pieces together. At 2 years the Shingle Oak is less than ideal, but, it will work. After this winter everything that goes in the stove will be atleast 3 years seasoned.
red oak/hard maple. I have about 1/2 cord spruce/cedar that I'll use first. i also get a load of NIELS to mix in with the splits.
