flyfish said:
I have wood that has cured, split and stacked, for two years but I did not keep it covered. Can I rotate the wood into the house and get it try enough? What about using ACS as I burn…will that keep creosote from forming?
Welcome to the forum flyfish.
You have a good question and on some points we will probably all agree. On others, not so.
Personally, after splitting and stacking our wood in April, we leave the wood stacks uncovered.....until late fall or early winter. Then we cover the tops of the stacks. It is very important if you are covering to cover only the top and not the sides. Yet, there are others (quads is a one with a great example) who never cover their wood piles. Yet, quads I believe does bring wood to his covered porch for a while before it gets burned.
Point is, most folks will cover the tops of the wood but not all. Either way will work. However, it is still best if you can go out and get some wood for the stove and be able to carry in dry wood rather than wet wood.
Will the rain hurt my wood? No. Wood is not a sponge....unless it is already punky. Wood generally will not soak up water. The water will run off and we've found that the day after a rain, our wood piles dry of amazingly fast.
There are some folks who burn things along with their wood to try to keep the creosote from forming and I have no problem with it. However, a much better practice is to always have 2-3 years of wood split and stacked; always! That means the first couple of years of wood burning will cause you lots of work but when you have reached the point where you have good seasoned wood you will find that the extra work was well worth the effort. They way the wood burns when handled this way is awesome. Just ask some folks who burned green wood their first year or two but now have good dry wood and they will tell you they are amazed.
Simply put, if you burn good dry wood, you will get less creosote (or none), won't have problems keeping the fire going or even lighting it. You won't have problems on reloading the stove because you'll have a nice bed of coals which will ignite the new wood. But the very best benefit will be that you will get more heat from your wood and you will not burn as much.
Here's one example: We put in a new stove and a new SS chimney in 2007. This means we are now going into our 4th year with this stove and chimney. We have cleaned our chimney exactly one time....for about a cup of soot and no creosote. That makes for a happy wood burner.
Good luck.
