Ok last spring I planned on heating with wood this year and didn't. This year no excuses. I have a $300.00 a month gas bill due to an old furnace and an out rageous gas company. Even still, I freeze to death during the winter, heating the house to only 60 degrees except for two rooms that I heat with a ventless gas space heater.
I had a tree cutter drop off alot of wood last year. He said it was a couple of cords atleast and I havent done anything with it. Also, my father-in-law has a few hundred acres that he lets a guy do timber work on. This guy fells the trees and delimbs them and hauls the trunks out. So, there are tons of good sized branches all around that I can have.
I have a single story ranch style house that is fairly well insulated. I plan to blow in more insulation either this year or next, depending on what it costs me to get a good insert and splitter.
Here are the specs. I have a fireplace that is located in the center of the house. I want to install an insert in it. The room is 422 square feet. It has two double door size openings. One leads to the hall and the other leads to the dining room. The main living area is 1400 square feet. This includes the living room, hall way, family room (where I spend most of my time), the dining room and the kitchen. The bedrooms and bathrooms add another 800 square feet to the house. I don't care if these rooms stay as warm as the rest of the house. I live alone and only use one bedroom and I like it colder in there anyway.
So, I want to keep 1400 square feet toasty warm and another 800 square feet some what colder. To give you an idea of the the houses insulation properties, I heat two rooms the family room and kitchen with a 20,000 btu ventless gas heater. These two rooms are a little over 500 square feet total. With the furnaces thermosat set on 60 degrees, these two rooms stay toasty warm with the addition of the space heater. Infact, if I run it for 30 minutes, these two rooms stay warm for a couple of hours easily.
What size insert do I need? And how much should I pay for one? I can get a Century Insert by Vermont castings for about a thousand dollars. This includes shipping to me and the chimney liner. Here are the specs on the stove. http://www.vermontcastings.com/content/products/productdetails.cfm?id=89
BTU output. 9,600-58,000 Btu/hr using the EPA Test Method.
1.3 cubic foot fire box volume
Is this insert big enough for what I need? Is is a good insert? What other brands do you suggest? Also is 1.3 cubic feet big enough for a long fire? I would like something that would burn all night.
Finally, how much wood do I need for a season? The average winter low here is 24.5 degrees and the average winter high is 39.5. It usually doesn't get really could here until mid december and warms up by april. I live in Southern West Virginia. So Three months of cold weather and another month of kinda cold weather.
Thank you in advance for your replies.
Karl
Karl
