What green thing(s) are you doing to contribute?
We compost what we don't feed the chickens. We also compost the waste produced by the chickens, garden waste, and large amounts of leaves. We grow a lot of our own food which also means we can. I do not drive, we have a car that is 8 years old and I haven't looked lately but I doubt if there is much over 65,000 miles on it. The house has with 5 exceptions all CFL lights, all five of the exceptions are rarely used. Pellets have replaced our 600 gallons of oil for space heating and I keep looking at the DHW and I'm not quite certain I can break even yet going to electric.
I'm currently making 18 panels of interior storms (well I have almost all of the parts needed), the goal is to cut a ton of pellets or better per year as well as even out the temperatures on the main floor.
I hope to get electrical usage down to an average of 400kWh/month.
We don't do it to be green, we are cheap ornery old Yankees and can really put the squeeze on the buffalo (that is how we pay for our vices).
We try to do the reduce, reuse, and recycle in that order.
ETA: For some of my vices consult the last line in my signature.
YAE: We stopped using hot water to wash clothes in years ago, and when our old washer sprung a leak we bought a new He model.
Frugality used to be considered a national virtue. As did the ability to make some wicked homebrew. >>
The thread made my remember what my Pepere (grandfather) used to do.... the old days weren't so green I think.
Tractor, trucks, car (he was a farmer) needed an oil change? Pull it over the ditch, drop the plug and let it drain to the ground. Asked him about it one day and he said "it comes from the ground, what harm is there with putting it back".
I think after a while he did start to put it in buckets though. Kept on it about it.
When I was little my father put a new engine in our family car and didn't know what to do with the old one that was dead. So instead of keeping the good parts and scrapping the rest he dug a hole and threw it in ! A couple of years ago he dug it back up and cleaned all the dirt off and to his surprise it looked like it was still in good shape 25 years later lol ! He probably looked crazy as he used a cherry picker and a chain fall off the back of his truck to lift it out of the ground ( chain fall was holding the cherry picker in the truck ) lol.
Pete
What everyone else said already....plus - we try to avoid buying anything new, or even anything used if we don't need it, or if it won't reduce our costs (energy or otherwise) over time. Learning to understand the difference between needs versus wants, and restraining purchases accordingly, is one of the keys. It's not only green, but it is also profoundly liberating in a lot of ways.
According to my 8 year old girl scout, if you fill a 1pt. 9oz. plastic water bottle half way, that is the amt. of oil it takes to make that bottle. Therefore, I will be installing whole house filters and a small UV unit to wean wife and said daughter from their addiction.
Ehouse
For those of you that compost, do you have a problem with critters? Skunks and others?
Critters and skunks take a little longer, but still compost out pretty well. With the others, I try to remove the plastic ID, shoes, and belts.
Likewise, I reuse or repurpose or recycle constantly. I have replaced all my exterior doors with good used ones, including my slider.
I insulated my rim joists with closed cell foam re-sawed from broken dock floats. Because it was free, I made them 4" thick for best effect. I re-insulated my attic with fiberglass salvaged from a motel being renovated. I built my boiler and the rest of my hydronic system from mostly reused parts, with the exception of fittings needed in the nick of time,
going so far as to purchase a bucket of ball valves, a heat exchanger and many lengths of copper pipe from the junkyard, and several superstor tanks from the warranty pile at the plumbing supply, which I then repaired. I am presently building a solar hot water panel which will be at least 90% salvaged.
Repurposing/reconditioning works very well for me, since I have a complete machine shop/fabshop on my property and worked over the years (and aquired tools for) virtually every building trade. Further, being self employed, I can fill my down time with such projects.
I had an apprentice who one day questioned why we were wasting time fixing an old free cement mixer. When we were mixing concrete in it less than four hours and zero dollars later, his tune had changed.
Reactions: begreen
Yes, although it's not always obvious.
Seeds from squash disappear. Bread disappears.
With a light snow cover I find raccoon prints. Not quite sure what they take. Squirrels take the bread.
I'm not feeding squirrels if I can help it so I'm thinking of getting a food grade barrel and making a compost barrel mostly for kitchen scraps.
I haven't seen any signs of mice or other animals. With no snow to capture foot prints who knows what comes and goes any other time of year.
I take a 25 foot roll of fence in a circle for a compost pile and can fill three of those in a Summer with lawn clippings and leaves.
Dune, you need a blog with photos. You're doing great man.
Squirrels, mice, rats, chipmunks, and various birds will take seeds and bread, here no large seeds or bread make it to the compost pile. The egg layers get that stuff. I also cover fresh stuff with a bit of dirt. If you keep the "good" stuff as the bottom all of the time most animals stay away.
I reuse pellet pallets to make my bins.
I have planted more than enough trees to compensate for all of my co2 output. Burn wood for heat. Re-use, repurpose, rebuild much old stuff (more of a hobby than a movement). Garden. Working on improving the house envelope. Pee outside.
CFL's have been in my house for 6 years, have not had a burnout. I think it has to do with the wiring, my electric was updated to 240 when I moved here. Before that house ran on 2 fuses.
Composting, paper metal and glass recycling, use gray water for outside watering, but don't have rain barrel yet. Keep TV to a minimum, raise my own vegetables, and try to keep my money local by supporting local vendors (does that count?). I make my own bread, buy in bulk, and only go the the grocery store once a month (I live alone), and even then it is in conjunction with another errand. In fact, unless it is an emergency, I rarely make a trip for one item. I only have one vehicle. My house was chosen because it is small, easy to insulate (invested in some serious insulation) and kept in good repair.
I could go on, but the bottom line is I have always subscribed to this mantra, even though the derision of others goes in and out of vogue over the decade:
Use it up,
Wear it out;
Make it do
Or do without.
Heck yeah it counts. "Keep it local" is catching on.
Due to recycling so much, it has taken me as long as three months to fill a 13 gallon bag of trash to put out.
We've even avoided purchases due to too much plastic or the packaging being #8 or #9 (or not marked at all) which isn't in the recycling program here.
My front lawn was a garden years ago and I'm slowly turning it back to one again. Cutting less and less lawn.
Planting dogwood trees close to the house so the roof doesn't get shaded for solar DHW panels and maybe even some day PV. I've even planted trees on my neighbor's property. Some I buy to be further along sooner, most I just transplant from the woods.
Thanks BG, I have been thinking about a blog for a while. I need a new computer, I can barely keep this one going anymore.
I have to restart it several times a day, and it has a redirect virus that makes google very time consuming and frustrating.
Thanks for the kudos, that helps a lot.
I have pretty much 100% wood heat.
I hang my clothes up in the basement (where the stove is) in the winter and outside during the summer. Haven't used the dryer in years. This is for a family of 6!!
I grow a garden, 100% organic. No pesticides or fertilizer. I don't buy hardly any produce anymore (pesticides, fertilizer) unless we are completely out. I'm still working on tomatoes, peppers, green beans, and broccoli from last season.
I fix things rather than throwing them away and buying another.
Putting a couple deer in the freezer every fall has to be greener than buying beef.
I've started raising my own "nearly free range" chickens with my FIL (and neighbor). They eat all the organic scraps, left-overs, grass, bugs, seeds, etc they can find and only get a little feed each day. Basically anything that isn't a rock and didn't have a mother goes to the chickens.
My truck is a gas hog, but enables me to do most of what is described above, so that's how I rationalize having it.
Much the same list of things here... Not sure it is a "green" thing, being "furgal/cheap" or what... but it is what it is.
I avoid buying anything new if possible - or buying things when possible. Reusing things is best, from the obvious things down to washing plastic utensils for kids lunches. Have found a nice pile of kitchen cloths handy for just about everything one uses paper towels for and thus we rarely buy paper towels anymore.
We recycle what we can - lucky for us that we have curbside pickup of most recycling (rinse and place in bins every other week pickup next to trash) so it is really easy.
Have worms to compost year-round, but they have a limited appetite as we only have 2 bins of them. They do eat all the coffee grounds and most veggies, but with 6 in the family we generate some overflow that lands in the trash in the winter. In the summer this overflow goes into the backyard compost pile.
Laundry is washed in cold, and we dry clothes on lines either outside when weather is dry and warm or inside the rest of the time (by the stove essentially). This has reduced our dryer (electric) use to only a few times a year for "finishing" loads or when guests visit.
Heating is mostly wood now like many of you. Oil still heats our DWH - working on finding another solution for that one...
We reduced our electric use in the house in many ways from cutting our computers from several desktops down to one notbook that is on most of the time (occassional second or third when needed). I believe most of our light bulbs have been replaced now with CFLs and the heaviest used lights are now being upgraded to LED bulbs. Family is well trained to turn off lights and other appliances when not in use. TV (rarely used anyway) is on a power strip. Many other measures taken - hard to remember or list them all... Overall we've taken what used to be over 1000Kwh/mo down to less than 475Kwh/mo average in usage. Still improving this.. Solar panels went up last fall and have been generating an excess for us which is nice, hopefully that will continue and we can choose where to put this energy to good use in the future.
Driving we keep to necessary, but this is where I'm sure we can improve. I'd like to drive a plug-in hybred if/when they come down in price, but cost is a major issue. We drive cars and maintain them the best we can until they are unreasonable to keep up. That seems to have been around 200K miles for us so we have a few more years on each of our cars before we have to replace them again. Perhaps the options will be better by then.
We stopped at 2 for this reason.
If everyone wanting kids stopped at 2 we'd have a net population decrease.
We had one, and I'm not even sure it was the ol' fashioned method. I swear my wife cloned herself to out-flank me.
Frugality used to be considered an important and patriotic virtue. One doesn't have to be obsessive to abhor waste.
As I personally don't believe in the green movement ( no insult meant to anyone ) but instead believe in taking care of gods earth I keep it clean. I do the rest as more of a cost saving effort for our family such as energy bulbs and fixtures .
Amen. Thank you.
