What is the best way to light pellets without the ignitor working?
Match.
I have a hand-held clicker torch, propane/mapp. Just pull trigger and aim then flame. Im inpatient when starting Lignetics.
Try rubbing two tiny little sticks together?
Build a tiny pellet teepee fire and add pellets one by one as it grows?
Self igniting torch and shove into a moderate pile of pellets with the stove on and usually can have a good walnut size amount of pellets glowing good that will easily catch when the door is closed in under a minute. Corn stoves have another added starting procedure or two.
Half cup or so of pellets just wetted with alcohol in a cold stove will work too. Liquid accelerants in a warm-hot stove is a big no no.
Reactions: Defiant
Hand Sanitizer works very well. It has alcohol in it and flammable warnings. :)
You will discover that replacing your igniter will be alot easier and alot less aggravating.
Reactions: Jack Morrissey
I'm in the same boat this year and I decided to go with the hand held torch method. After I serviced the stove last week, I tried it and was very impressed by how fast it works. No more checking the stove every few minutes to see if the pellets lit yet.
Reactions: Defiant
+1 -- Torch works great...
Reactions: Defiant
Torch works really well. My choice.
But everyone doesn't have one, and they are pricey.
The gel stuff works good too. I think the tip is to let it soak
in a few minutes. If you light it right quick, it will just burn off the surface
of the pellets...
Best to put some pellets in, then gel, then more pellets..
90% ISOPROPYL ALCOHOL is the best and cheapest way to start your pellet stove. Take a handful of pellets put it in a small plastic cup, pour some alcohol into the cup to coat the pellets wait about a minute then pour the pellets into the burn pot, light it and you are done.
I have been using this method for 2 years with no complaints.
I might try doing it this way, Thanks
I use lamp oil, like alcohol soak a few for a couple of minutes then light.
A quart almost lasts me a whole season
