I’ve been searching and reading and searching and reading till my head is about to explode. I know, from what I’ve read, that some here can’t stand long posts. So, sorry in advance. I guess I’ll get the message based on the reponses I get. LOL. It’s about size and if I should go cast or steel, basically.
No, I am not in a climate where I would need an extremely hot fire 6-10 months out of the year. I am in Pensacola FL, mainly during the winter months. I leave when this place gets hot and muggy. I was thinking, if I described my home conditions during the colder months, maybe I can get some guidance on sizing, which might be best, cast or steel. Looks like brands area more a matter of choice, appeal, quality of build, which I want a well built stove that will last till death do us part. Well. Here goes...
The next few days it will dip down to as low as 20 F, with highs around 45. By next week, we’re talking 41 to 65, then it will dip again; this is the pattern here during winter months. Humidity is almost always high, between 80 - 100, with winds and gusts from 2/3 mph on upwards of 30, out of hurricane season. This pattern will run from mid Oct thru Mar, usually, but can stretch both ways a few weeks. There has been snow flurries here, the last leaving about an inch for the night and early am hrs. So, we do not have real winters here, to speak of, but it gets COLD, and the cold lasts for a few months with varrying fluctuations.
All that said to say this, I am reading that there needs to be serious consideration for the size of the stove based on regional weather patterns, which I get. But, many here would suggest that bigger is always better, because bigger can accomodate small to larger fires as needed/wanted, while small can not; with small, you get what you get and no more. This does make sense, but I do not know if this is a fact for stoves given the area it needs to heat. Then I need to factor in the size and style of the home, the amount of insulation. Well, ok. I am a new comer and I’m working hard to figure these things out, before I drop hard earned money on the table.
The house is a single story, 2100 sq foot rancher, brick veneer, well insulated, as it has open cell sprayed on foam on the inside roof deck; this usually keeps a difference of about 10 f between the attic space and inside of the house. The walls are fiberglass pink stuff, and all windows and doors, to include the garage doors ( 2 singles) are high E, tinted, hurricane rated (160 mph) units. Roof pitch is 5/12, for a low profile in high windy conditions. We run ceiling fan’s in each room on low all summer long just to keep the air moving around, while the HVAC cycles at around 70 f, which keeps the house at a very comfortable feel even though it’s 85-95 w /100% humidity. We have a 3.5 ton HVAC system, along with two mini splits, one in the master suite and one in the guest BR, for AC comfort during the summer. The mini’s run when we really want to sleep cold.
We use two electric oil filled radiator heaters to do the supplemental heating in the master suit and one in the main area of the house, mainly to keep the chilled cold spots out. The HVAC is usually set at around 66 f, and cycles sufficiently to be able to feel comfortable with a long sleeve on, sometimes a sweater. But, all of this is not good enough for me, husband and I.
The old fireplace insert is out, and we really need to find a stove we can enjoy. A licensed, insured, experienced chimney and stove contractor is coming out to look at our project next week, and he asks that we have some idea of which stove we’re going with, so he can assess the project build. The remodeling contractor is ready to do the redo and he needs to know which stove. I am still undecided and digging, pulling my hair our now.
I’m looking at non-catalytic, no blower, straight single wall pipe inside. Flat top for setting pots/cooking on. Easy to start and control. Ash drawer. Glass front for breathtaking views. Osburn, Regency, Lopi, mainly are the ones I’ve looked at. Medium size, but not sure, can go larger; I don’t see that much difference.
Burn times? Would be great to go 8 hrs, have warm coals to restart in the am, for sure.
Suggestions/directions...
Size?
Cast or steel?
Thanks!
Size?
Cast or steel?
Thanks!
![[Hearth.com] What size stove? My head is spinning, so many things to consider...regional weather, size of home, etc. [Hearth.com] What size stove? My head is spinning, so many things to consider...regional weather, size of home, etc.](https://www.hearth.com/talk/data/attachments/306/306027-c82dc56aa0463214f6bbf5ef131de645.jpg?hash=T1dxcZirKp)
![[Hearth.com] What size stove? My head is spinning, so many things to consider...regional weather, size of home, etc. [Hearth.com] What size stove? My head is spinning, so many things to consider...regional weather, size of home, etc.](https://www.hearth.com/talk/data/attachments/306/306029-31bbcfe60b4f9165ebced66b9c278b24.jpg?hash=7IklR4Y8Wo)
