Hi all, new to this site but not stoves. My wife wants a new stove and for me to get rid of the OSLO!! oh no help... Here are the complaint's: 1) The fresh air intake that is located in the back seems to starve the fire vs. opening a slide in the front of other stoves we have had, we constantly leave the side door cracked to really keep the fire going ( I know that burns more wood and we loose heat). There were 3 holes feeding the fire from this intake right inside when you open the front door. I drilled two more holes trying to increase air, made no difference to speak of. 2) When the fire goes completely out the box gets really cold and that becomes an issue getting it started again. Getting puff backs is common ( I crack a window which helps) 3) I have hydro air system(forced hot air & ac) that draws air from the main level. the intake is 16' right in front of the stove. So we have gotten black soot drawn into the ducts and blown through out the house. (not the stoves fault) we try very hard to shut the heat to the rest of the house so this is avoided. Obviously that sucks when you need to keep other parts of the house warm. BUT even with the door closed I believe we get soot sucked out of the intake? sound crazy? Now here is the set up: off the top of the stove vertical 24" to the first 90 then travels slightly uphill for another 19" where it changes to Dura vent (or =) goes into the thimble and out to a "T" (total horizontal distance about 36") . The "t" is there so I can pull the bottom off and clean the riser complete from the top. Distance from the "T" up to the Vac u stack is 16' . The ENTIRE riser is Dura vent and enclosed to outside air in an insulated 24 x 24 chimney enclosure. Just Trying to keep the chimney warmer and avoid issues. We get a constant NW breeze so I change the normal cap to a Vac U Stack which helped 75% on blow backs. I could not go straight up inside due to truss dead center and didn't want to look at an offset in a cathedral ceiling. Your thoughts? What would you do to improve the situation?
especially with such a short stack.
? that makes for poor drafting all by itself. One more thing flue exit needs to be higher by 3 ft, than any thing in a 10 ft radius, Vac-u-stack not withstanding. That"s a rough rule of thumb- modifications sometimes are required as the roof line or adjacent structures including trees can cause down drafts in the vicinity of the flue Out side air kit ( OAK) - You very likely need to set this up if not done already BUT the intake needs to be on the leeward side of the prevailing winds, additionally if this ends up being a long run you will need to up size the the line from the normal (I think 3" ) to 4"-6" depending on the run length ( just like on the HE furnace longer the runs require greater diameter for intake and exhaust) and yes, twists and turns reduce the effective diameter all so.
