Whether to install a VC Vigilant, and how else to reduce puffing
Jprinter
1
Montana
Hi,
We’ve had a problem with our wood stove back puffing in our house, and are wondering if we ought to consider swapping it out with another stove (along with other, suggested changes). Some background first…
I’ve currently got a Lennox wood stove (model CI1000HT) in the bottom floor of a bilevel house (roughly 2,500 square feet). Our house was built in the late 1970s and, like other houses in our neighborhood, it is a tightly sealed house — too tight, in fact, with little airflow. That, combined with the stove’s location on the bottom floor, no intake ventilation for the stove, and a single-walled stove pipe (which gets quite cold during the winter, and apparently wasn’t fitted at the right angle) contributes to the back puffing.
Yes, we do heat the stove pipe and open windows and doors before starting an initial fire. It helps, but our house still gets smokey even will all of these measures. And yes, we’ve had the chimney cleaned recently.
The chimney cleaner suggested we redo the pipe — both using double walled pipe, and refitting how the stove is connected to the pipe, and is shaped at the right angle from the stove to the wall. (He also suggested installing a draw collar to the chimney pipe.) And some have suggested that after all of that we might also want to consider swapping out the Lennox with another wood stove that’s breaths better.
Anyway, I just got a free Vermont Castings Vigilant 1977 that’s in good shape. I’ve cleaned it and, as far as I can tell, nothing seems broken. I’ve done some research on the stove, and know it’s an older, well-built, sturdy stove — though it was "hi-tech" (for its time) by using the damper for secondary burns. I can see how it might “breath” better than the Lennox (i.e., through the temperature door in the back, and air valve). But I know it’s less efficient than more modern woods stoves, and that it lacks certain environmental features that found in modern stoves.
Overall, would others suggest or discourage me from replacing the Lennox and with this VC Vigilant 1977?
Our main concern is avoiding back puffing for any stove. So, I’m wondering if this VC Vigilant 1977 would be better a better fit for our house, as far as being able to “breath” better — and less inclined to smoke us out compared to the Lennox?
If I do install this stove (even as a temporary solution) I could install a double-walled (and better fitting) chimney pipe, and redo all the stove gaskets. Beyond that, we’d crack a window to prevent back-puffing — and I’d welcome any other ideas for additional mitigation. But again, I’m first trying to determine if it’s advisable to install this VC Vigilant 1977 in the first place.
Thanks!
The Vigilant, if in good working condition, will breath easier, but will be less efficient than the Lennox. However, backpuffing may still occur because changing the stove may be treating the symptom and not cause, which I suspect is negative pressure.
If you can tell us more about the house and include some pictures of the current stove setup (including stove pipe) and the chimney outside, we may be able to offer suggestions to address the negative pressure. There are several possible causes. Some are easier than others to address.
Here is a good site with a series on chimneys that explains causes of negative pressure:
I lived with, heated 100% with a 1970s vigilant for a couple of years in the early 80s. Perhaps my view isn't worth much, because I was very young and renting, and the whole group house didn't know what we were doing. And wood probably not dry enough at all. And those were cold winters in Vermont. I remember our wood was stacked outdoors in rows, and we had to dig it out of the snow. I don't remember the details of when we stacked the wood, but it certainly would not pass my standards now, I'm sure!
Compared to almost any stove I've had since, the experience was really bad. We were cold, pipes froze, chimney full of creosote. Like I say, if I did it now with my dry wood and understanding what to do, it might be better. It was really cold, sitting right in front of the stove.
Modern stoves are amazing -- more heat, less creosote, less fiddling, no (or minimal) chimney fire danger. And you'll burn half the wood with a modern stove.
