Forgive me if this is in the wrong forum but it bridges the gap between wood stoves and pellet stoves
I also have a Harman XXV pellet stove that is rated at 50,000 BTU's. I feel the blowers on this unit are better than my Lopi. It is also a stand alone unit so it puts off some residual heat too - not a ton but it does get warm. Plus i can run it 24/7 @ 50,000 BTU's for the most part - except for cleaning which takes about an hour and then i am back up in running 20 minutes later.
I am fortunate enough that i have two fireplaces in my home. What i am thinking about is moving the wood insert to my other fireplace that is not as central to the house and putting the pellet stove in the central room in front of the fireplace, making it the workhorse of the heating system. Then for this year i would use the wood to supplement the pellet stove - if needed. Next year i will have better wood available and try to rely on the wood stove a little more. But i have to say i am very attracted to the convenience of pellets.
So my question for you all is this. Given my situation - would you rather have a constant 50,000 btu's (Pellet stove) in the centeral rpart of the house or a stove that can get hotter but is not running at max capacity all the time and at times goes cold.
I am assuming the constant 50k would keep the house warmer?
- No making fun of my sissy stoves and i know some of you will say ..... " Neither, id rather have X, Y or Z......" I get it - i am limited on options.
- Sorry for the long-ish post.
