Never had a problem with my Whitfield Advantage III stove. On the third auger though, after the original lasted some 15 years, the second one from E-bay always made a noise and only lasted 6 months. I started having trouble last Jan. and Feb. The original controller went, had to replace that and get my old one fixed as a backup. I also would not burn all the pellets in the pot. Had to clean the grate every 20 hour of unburn pellets. So yesterday I changed the exhaust fan I bought a year ago. Open the side fan area since 1996, and it was jammed with ash. Got my ash vacuum and cleaned it out good. Can't believe it was so packed in there. Replaced the fan and I'll keep the old one as a backup. Started it up and it's running perfect, ran all day at number 2. Just had it on low overnight and the ash pot is clean. Everything is burning all the way down. The room fan is next for replacement. That is original too.
So if you have a Whitfield, I guess it would be a good thing every 4 - 5 years to remove those 5 nuts and clean out that fan area. You can get the gasket separate, make sure you buy the correct size.
