Who did your install?
djlew
224
New Jersey
Hey all,
Nice to not be stuck on the Jotul and General forums! I did a brief search and didn't come up with anything on essentially starting the process of installing a wood boiler or wood furnace. Basically, my system currently is a heat pump with a 3 zone controller and motor dampers that has a tough time keeping up when it gets too cold. I have my Jotul 602 V2 that I can get going and once it is, it works to heat the main floor but a couple rooms down the hallway stay cold and, of course, inconsistent. Lovely for the ambiance though.
I was discussing with a friend and he mentioned why not look into a wood boiler or wood furnace? I did a bit of research and it seemed like a viable option compared to upgrading the wood stove, installing cold climate mini splits or a cold climate 4 ton heat pump. Besides just viability questions of tying into existing ducting, for those who had an installer do the work, who did you go with? Might sound stupid, but was it your local HVAC company or was it your local fireplace dealer? I only ask because I'm not sure of the flue requirements for wood burners vs. traditional stoves. A ton of HVAC companies do boiler work, but only mention gas and oil. I plan to call around, but to save some runaround I wanted to see how you all started your process of getting professional information.
As always, thank you all for the help! And if this info exists elsewhere, I would love to take a look and close this up.
The flue requirements for a wood furnace are similar to that of a wood stove along with the same caveats for basement installation regarding draft. Some basements are negative pressure zones.
Kind of what I figured, and to me, sounds like a combo job between an HVAC contractor and somebody to install a flue like a chimney service company. Nobody around my area actually mentions installing wood boilers or wood furnaces as a service. On the surface it seems like an installation nightmare for somebody in my situation.
Yes, it looks like you will be the designer and general contractor, unless you can find a guy/company to spec it, price it, and install it.
Reactions: djlew
So are you leaning towards a forced air wood furnace, or a wood fired hydronic heater? And if the latter, indoor or outdoor?
Reactions: djlew
Adds up, I saw a lot of DIY here which is nice but I'd be concerned with insurance implications.
I loved the idea of the hydronic heaters. I feel like in my case a wood fired furnace probably made the most sense but I do wonder if the outdoor hydronic heaters were actually easier to install. I have plenty of space but I know that PEX can be pricey. I guess my answer lies in the nice to have vs. Simplicity possibly.
I built my own system with the design help of the guy who owned the store i was buying my stuff from including the boiler.
My system is in it's own building,which includes the wood boiler, 1000 gals storage and my backup oil boiler.
At the time the guy told my wife, as she was complaining of the price of parts she was picking up. That what i had built would have cost over 50K to have built.
I went with the remote building to get away from insurance BS, and to keep all the mess out of our home as my wife and daughter had asthma at the time.
So far 14 years in i have zero regrets about the system i built, yes i have to walk 150 ft in the cold one way to go stoke the boiler. But i have a warm workshop 24/7 whenever i decide to go work on a project.
I totally understand this way of doing it. The more I research, the more I lean towards an outdoor system for that very reason. It's tough, because on one hand I ask myself well why not just a two zone Mitsubishi MXZ mini split and have a unit in the rooms I want to heat when the York doesn't keep up, but I have a lot of access to wood. That, and some of the outdoor boilers I see are upwards of 10-15k USD. I'm trying to avoid electricity as rates are increasing seemingly every season. If you search me up on the forum you'll see me struggle with whether to go with mini split, propane, upgraded wood stove, or wood furnaces/boilers. Tough where I'm at it seems. Thank you for the input!
Reactions: hobbyheater
If a heat pump will work for you that is the way to go. They are up to 400% efficient. You do no work or design. However, as you know they must have a head in the room (OK for you), they need power to run, and if the outside temperature is really low, they don't perform. They cool as well, which is a big plus if you don't have any AC or need a bit more.
Reactions: sloeffle
Well, for what it's worth I have a forced air wood furnace, the Kuuma VF100.
I do somewhat wish for a boiler system, but mainly for heated floors, and the ability to thermostat control the house temp to within a degree or two, but the cost of installing a hydronic system is a non starter for me, even diy.
The Kuuma does work really well, and I only had to somewhat modify the existing duct system to tie the Kuuma in..."backup" heat is fuel oil. Have central AC too...
Do you have access to firewood and the space to store 3 to 4 years worth of wood and the time involved ?I have just as much money invested in a firewood processor, saws and a pickup to haul it !
Yeah, my only concern after a few winters of freezing cold temps because my York freezes when it gets below 32F is that either a cold climate heat pump will cost just as much or a mini split won't provide the amount of heat I need at sub freezing temps. I know some are rated as such, but just a concern I have. I would also need a 2 zone system to just keep the bedroom and living room at reasonable temps until I can start a fire in the living room at least.
I really do think something like this is a good option for me, but finding an installer has been tough. I did find a few folks who said they've done installs in the past, but a brand new flue and all that makes the project seem a bit more of a groan than I would want. I'd end up having 2 rocket ship looking flues! 😂
I do! Which is why it was an attractive option. Some of my equipment could always use an upgrade but I do have access to the wood and storage. It would also force me to get more processing done LOL
Having installed both a wood furnace and a hydronic heater. The hydronic heater install is going to be a lot more complicated and expensive. For a good hydronic heater, I'd plan on spending north of 20k. You can buy a lot of electric for that much money.
Both of my installs were self-installs. If you buy a OWB from a dealer, I'm sure they'll install it for you, but I've seen some dealer installs that were less than ideal. I'm not aware of any company's that sell IWB's that will do an install for you. I probably have $300 easily in SS ball valves in my install. I've seen pictures of multiple dealer installs; no ball valves to isolate the plate or heat exchanger and stuff looked like it was thrown together. They were done as cheap as possible.
These 2000W (or 1500W) heaters are a good way to get some extra heat when needed. If you were to calculate the cost of ownership compared to wood or heat pumps (for running part time) it's going to be way less. Still, you need power. If you already have a way to heat during a power outage, it might be worth considering.
  • [Hearth.com] Who did your install?
Reactions: djlew and sloeffle
Just wanted to thank you all for your input. Funny enough, I got a call from the natural gas company and it looks like we might be in the service area for natural gas. All things considered, I think putting in a proper natural gas furnace might be the best option if all comes to fruition. Then back to the little Jotul for me!
Reactions: sloeffle
Will you have a forced air system? You could have AC too. Also good for BBQ's and a pool heater. Heater for the garage?
Hmmm not too sure. I wanted to find a good contractor who will do a manual J and give me a good recommendation. I figured we would end up using the heat pump in the summer and shoulder seasons and a Goodman or Carrier furnace essentially as second stage. The heat pump install was a homeowner special before I bought. My wife likes the idea of forgetting about the heat pump for all heat and just using gas. Seems kind of like a waste to me though.
