Can anyone tell my why a stove would need ceramic insulation board and firebrick in the bottom. Mind you this is NOT a baffle, bottom of stove layered as follows firebrick, ceramic insulation board and then the steel of the floor.
I am asking this because I purchased a WoodPro WS-TS-2500 for our new home. (1550sq feet under a/c). My husband thinks the firebox is not tall enough to load it up for an overnight run. I have since purchased a Country Hearth 2000.
After inspecting both stoves I feel the better made one is the WoodPro. I think I can convince him to use it if I remove the layer of ceramic in the bottom creating a little bit more room.
I think, but not sure, that the manufacturer put that layer in for a smaller distance from combustibles. This would not be a problem, we will have it diagonal to the corner with 12" from wall to closest corner of the stove.
Can anyone help me out here?
Both stoves list the same 2 cubic feet and 21" logs. My husband likes to pile wood up past the firebrick. He would not be able to do this in the WoodPro.
