maple1
What is the cleaning schedule for a rocket thermal mass stove? And how often do you have to replace the exhaust pipe?
..and how do you clean it?
![[Hearth.com] Why dont we all want rocket mass heaters? [Hearth.com] Why dont we all want rocket mass heaters?](https://www.hearth.com/talk/data/attachments/215/215528-9d2c85f8609f7d9f4503c07bf9adb42d.jpg?hash=UY1OgyO-Oc)
I still don't see how you can get the draft started when the stove is cold (or reverse drafting).
What keeps fly ash out of the main heating chambers?
To be 790% efficient you are no longer extracting heat from wood, but using the energy to run a heat pump, and that is not what a Rocket mass stove does
I really think that it is a promising technology that could work for some people. But they need to be realistic with their numbers if they want to be taken seriously.
One simple thing I would be curious to see is flu pipe or chimney temp readings on one of these units both through an entire burn and also through an entire 'coasting' session when the fire is out.
The temperatures are so low they must be at the chimney outlet , though this is not stated , though the science direct paper on Belgian stoves states it is 1.8 m above the stove
Given its size and what would likely be unequal transfer throughout.
So again what stoves are you comparing to when you come up with the 10x number?There is an insulated chimney in the barrel. It is about four feet tall. We call it "the heat riser". When starting a rocket mass heater, you must prime it. Different folks prime it in different ways. I usually put some paper under it and then ignite the paper. While the prime is burning, I add the rest of my paper and kindling to start the rest of the fire.
Once the heat riser is primed, we have a pretty good push in the right direction.
Nothing. Which is why we have cleanouts. We clean out the fly ash about once a year.
We usually see efficiency of about 93%. Sometimes more, sometimes less.
And, we are more comfortable with one tenth the wood.
Therefore, the numbers from the woodshed are not dependent on the efficiency of the burn alone. There is a richer story.
And these are our numbers. And a few of you will look into and decide to try it out. And then they will report similar numbers.
Those of us that have taken the leap are very happy. And when we share our enthusiasm, it is as frustrating to us as it is to you.
Maybe over the winter you will find yourself visiting somebody that has one and you can experience it for yourself.
Matt Walker is another rocket mass heater designer that I have a lot of respect for.
(broken link removed to http://walkerstoves.com/index.html)
We had a good exchange in this thread about the woodstove decathlon : http://donkey32.proboards.com/thread/1908/woodstove-decathalon-washington?page=2
His takeway , based on running both types of stoves side-by-side for a week, was that a modern catalytic stove (Blaze King, Lopi, Woodstock) had equal or better overall efficiency than the best current RMH designs, with slightly lower emissions.
If inquisitive people continue innovating on the RMH design, I would not be surprised if they catch up to steel stoves. You never know where the next great idea will come from.
Again what type of stoves are you comparing to when you figure your 1/10th. Because it makes a huge difference if you are compaing to pre epa stoves or notThat was two years ago. Matt is still doing a huge amount of work in the world of rocket mass heaters.
If you wish to measure just in terms of efficiency of the stove and are not concerned about what happens in the woodshed, then go for it. I think Matt and the other rocket mass heater folks are looking at what is happening in the woodshed and continuing to focus on rocket mass heaters.
I very carefully measured the wood used in our rocket mass heater last winter. 0.60 cords of wood on a particularly cold winter. I think that with a few modifications and a warmer winter, I could get that down to 0.35 cords of wood.
And if you don't believe my numbers, cruise the internet and find the experiences of others. And now that the idea is in your head, it is possible you will mention it to somebody in the next month or two and find yourself visiting with somebody that put one in and can tell you their experiences.
And i would still like to know how you determined the wood is safe where it is. The fact is as a pro i cannot put one of these in wothout them being spproved in some way. And the same goes for anyone who will need an inspection or insurance.That was two years ago. Matt is still doing a huge amount of work in the world of rocket mass heaters.
If it is oversized for the house there is no reason it couldnt overheat things. That issue comes down to sizing the appliace correctly and knowing how to run it for your situation. For example i just bought a new house and i have had it to warm a few times because i am learning how much heat is needed. I will have it down after a season and wont have much of an issue. The difference between the two is with a mass heater if you make to much heat it is going to be to hot for a long time. While with a stove it will be at most 6 to 8 hours till things cool downI'll say one thing that strongly favors the mass heaters efficiency claims and I see it here often.
"Help my stove is cooking me out of my house" And here's the common response "Open the windows"
Now if you are venting all the excess heat to the outdoors you are not too efficient no matter what the stove spec is.
I don't think the rocket mass heater guys suffer this problem.
I personally am not willing to give up that massive ammout of space in my home.Or enjoy some fresh air.
I think this stuff looks interesting.....in someone else's home. But I don't see it catching on in any large capacity due to certification/code and insurance as bholler mentioned. To me it seems it will always be a fringe thing, someone is going to have to really want this and be very dedicated to having it. Because a professional company is unlikely to come and Service it or try to inspect it for insurance or safety.
Wood heating isn't rocket science(see what I did there? he he he). I am quite comfortable with the amount of wood I use. So that being said why would I ever want some giant questionably attractive heating device in my home?
