- Jan 30, 2013
- 32
Hi all.
So my AHS wood gun e140 has been running since November and keeping the house warm but I have a few questions, or maybe looking for some advice or experience from other users.
First is the creasote that is created. The boiler is vented to a 6" single wall stainless pipe then to a approx 35" stainless liner in a interior masonry chimney. All the joints are sealed with high temp sealant. I noticed some creosote forming on the outside of the chimney in early December and attributed to loading the boiler with wood that had been rained on and loaded wet with a high moisture content. I have since been bringing in about two weeks of wood at a time. Most are large splits with about 20%mc average. I shut the boiler down for a day and pulled apart the flue and found a considerable amount of creasote (light fluffy, not thick tar type) build up in the flue. I swept the rest of the chimney but from how this boiler was advertised and described is 2-3 mid season chimney cleanings normal?
If this is not normal I would my first guess would be an air leak somewhere allowing the fire to smolder. I adjusted the load door so that there is no creasote leaks during shut down. I don't seen any visible signs of leakage anywhere else. How do I know if an air leak is allowing the fire to smolder when the green light is off?
Other thought is since I could only fit an uninsulated liner in the masonary flue is that possibly the flue gasses are cooling too much. About the last 15feet of before the cap there is enough space that I could push some roxul or similar product down where the chimney exits the roof to insulate the pipe.
2nd it does create more visible smoke than I thought it would. on start up quite a bit less once it is hot and the refractory is up to temp. This is my first year burning with a boiler. My previous experience has been with older wood stoves that run wide open, hot, and create little to no smoke or creosote. (Barely ever needed to sweep the chimney) That being said I'm on par to burn about the same amount of wood this winter heating the whole house and my DHW as I had previously with space heating with the wood stove.
Thanks
Craig
Thanks
Craig
Operators like Krinkov who are heating 4K sq ft have the best experiences with these units.
