Hi all,
I've been reading old posts on here while researching our options, but haven't quite found the answer to this question.
We were planning to put in a wood stove to supplement the heat pump that came with our house (which does not work great in our climate and is expensive to run). Ideally we'd like to be *mostly* heating with wood in the winter.
We've now had two people try to sway us to get a high efficiency wood fireplace instead of wood stove. They claim that they are as efficient or more. I raised concerns about it requiring a blower to heat as well as a wood stove (based on some of what I read here), because we also want this as a heat source if the power goes out (we're rural and that's not uncommon) and we'd have to run new electric for it. The salesperson responded that it isn't necessary to have a blower and that the heat will still be the same.
So - is that true? Aesthetically, I would actually prefer the fireplace (we already have an old standard fireplace that we were planning to remove and seal up the space), but not to the point of compromising our ability to heat (which is the whole point).
Thanks in advance!
Thanks in advance!
