Woodchuck Wood furnace - Model 4000
I recently purchased a WoodChuck Wood furnace, Model 4000 and in the process of installing it in my basement.
It was used, the guy I got it from removed it and was going to a pellet furnace.
From the info I got, it’s about 15 yrs old, its from 1993, but its in very good condition, inside and out.
I’m just setting it up now, still have to get firebricks for it, and a plenum made up, He gave me the manual for it, and i've been on on-line trying to read up what i can, but any tips or info I should look out for???
One of the first questions I have, it has an 8” flue coming out the back and my flue opening in the basement wall is only 6” .
My friends that came over to help move it in the basement (its one heavy unit
) said I can just get an 8 to 6 reducer.
I’ll have to do that, but is it best to have the reducer close to the stove, say as soon as it exits out the back or should I run 8” out the back then reduce it down right before it goes into the basement wall?
From the back of the furnace to the wall will only be about a 42” – 48” run. I'll have an 8" rise from the back of stove to the flue in the wall.
Also, i have read a lot about putting a damper in the stove pipe, It’s a forced draft furnace and where the draft comes into the fire box so it is suppose to be air tight, but not sure if having a damper will help extend my burn times.
) said I can just get an 8 to 6 reducer. I’ll have to do that, but is it best to have the reducer close to the stove, say as soon as it exits out the back or should I run 8” out the back then reduce it down right before it goes into the basement wall?
