Just some notes on our recent install because "Wouldn't a wood stove be nice?". Install is into existing fireplace built 1973 I believe, all in good shape.
Flue tiles are 6.5x11.5 inch inside measurement, 20 feet of flue plus a couple feet of smoke shelf chamber. Did a trial pull with a piece of 3 foot piece of 6 inch pipe that made it through OK, so I figured 5.5 inch flex would be manageable. Went with Flex King because near as I can tell loose insulation is permissible should I choose to go that route.
Busted out cast iron damper frame and chipped out some of the smoke shelf to get enough of a straight shot.
Found a used Fireview on CL. Went catalytic because it's a small area to heat on an occasional basis, and from what I gather a small steady fire is easier to manage with a catalytic stove.
Plate is 12 gauge because that's what I had, it rests on the lip that the damper used to rest on and is held up in the back by a couple pieces of concrete blocking cut to fit. On top of plate is a piece of 1 inch foil-faced mineral wool cut to fit snug.
Rug is supposedly fireproof. Still need to add a shield for wooden mantel.
Thanks to all the folks here, I was able to take advantage of a lot of valuable experience and insight.
(Plenty of seasoned wood, but it's all 22 inches!)
![[Hearth.com] Woodstock Fireview in Fireplace, Flex King Pro 5.5" [Hearth.com] Woodstock Fireview in Fireplace, Flex King Pro 5.5"](https://www.hearth.com/talk/data/attachments/115/115341-1e30370b4c9c0016d085526c4b4540af.jpg?hash=kWLNCvIvnX)
One great thing about the Woodstocks is that if you need parts, they won't cost you an arm and two legs.
![[Hearth.com] Woodstock Fireview in Fireplace, Flex King Pro 5.5" [Hearth.com] Woodstock Fireview in Fireplace, Flex King Pro 5.5"](https://www.hearth.com/talk/data/attachments/115/115781-49d39bd54bc75418e6dac0ffcb735411.jpg?hash=AwaWCywgLL)
![[Hearth.com] Woodstock Fireview in Fireplace, Flex King Pro 5.5" [Hearth.com] Woodstock Fireview in Fireplace, Flex King Pro 5.5"](https://www.hearth.com/talk/data/attachments/115/115782-67770f24ce28c57161eb41177f027608.jpg?hash=B_BCLysrUM)
![[Hearth.com] Woodstock Fireview in Fireplace, Flex King Pro 5.5" [Hearth.com] Woodstock Fireview in Fireplace, Flex King Pro 5.5"](https://www.hearth.com/talk/data/attachments/115/115783-c51da92d169b5a6c9f3a2d96d91d59f1.jpg?hash=ZGY10kXA98)
