So I picked this up from the marketplace last weekend. It’s my first Woodstock stove, although I’ve wanted to get my hands on one for years! I got a sweet deal on it and am excited to fire it up!
Beauty!So I picked this up from the marketplace last weekend. It’s my first Woodstock stove, although I’ve wanted to get my hands on one for years! I got a sweet deal on it and am excited to fire it up!
I’m replacing all the gaskets. The cat needs replaced for sure. I contacted Woodstock, they no longer offer the ceramic cat, onlyVery nice. Give it a good going over, checking gaskets and cat so that is is ready for fall burning.
The Jotul firelight. I’m moving the BK to the basement.What stove will the Fireview be replacing?
I'm looking forward to hearing about your experience with the Fireview.The Jotul firelight. I’m moving the BK to the basement.
Steel which is back ordered.
I can get ceramic cats from a different supplier, I may spring for the steel cat from Woodstock though. Assuming they will have them in stock by fall.The whole nonavailability of mission critical wear parts is a strong point against cat stoves.... or maybe just woodstocks. (Ducks for cover).
If not for the huge rear clearance requirements, my hearth would have had a fireview on it. Double pane glass, super easy cat access. Respectable burn times.
If they are truly in great condition somewhere near $1000. I buy and sell stoves all the time, $1,000 is probably the top end, but not uncommon.I bought a older one this summer for $50. it needs the top plate, it was cracked and I just found another one that just need a cat for $150.. What do these stoves go for after new cats and any parts that maybe needed? Thank
I sold my Hearthstone for $1000 with a cracked stone. Like most all of them do...I bought a older one this summer for $50. it needs the top plate, it was cracked and I just found another one that just need a cat for $150.. What do these stoves go for after new cats and any parts that maybe needed? Thank
so far I’ve noticed that all the working parts seem far superior to Hearthstone products. Many of the Hearthstone stoves I see are cracked. One big big difference I see is that the Woodstock has no veins in the stone, almost every Hearthstone has veins in each and every stone, which often is where a crack develops.
Scooore!I got a sweet deal on it and am excited to fire it up!
Yeah, the steels are always back-ordered at Woodstock, not sure what the deal is? I think both Ws and BK steels are Applied Ceramics. That said, I wouldn't hesitate to get a ceramic if the steels don't come in soon. I'm ahead of the curve, and have a steel in stock for my Ks. Sure, the warranty clock is ticking but I don't anticipate ever calling in a warranty..haven't so far. I just go ahead and replace 'em after several years when performance starts to tail off. They aren't very expensive for these stone stoves.I can get ceramic cats from a different supplier, I may spring for the steel cat from Woodstock though. Assuming they will have them in stock by fall.
It's 18" with the heat shield, maybe due to the rear-flue only setup. You tore down a masonry chimney, right? The Fv wouldn't line up with the chimney out the roof that you had with your 30-NC?If not for the huge rear clearance requirements, my hearth would have had a fireview on it.
I often harp on the Woodstock quality..maybe more than I should since I haven't seen a lot of other stove brands other than what's in the local shops. But the Fv and Ks appeared to me to be built like tanks. So does the Buck 91. In your line of work, you've no doubt seen the innards of a lot of brands, and knew what you were buying with the Fv. Maybe later when you try a Woodstock hybrid steel, you can compare the build quality to other plate-steel stoves.so far I’ve noticed that all the working parts seem far superior
Man, $150 is cheap, if it's in decent shape. Maybe in the big Chicawgo-land market there are more around, driving prices down..?I bought a older one this summer for $50. it needs the top plate, it was cracked and I just found another one that just need a cat for $150.. What do these stoves go for after new cats and any parts that maybe needed?
I’ve moved since then. I still need to build a hearth for it. I’ve just been too busy to do much around the house.Post some pics when you get 'er in and fired up. Seems like I remember a pic of a hearth area upstairs, but you might have moved since then..?
It’s the busiest I’ve seen it! Like most years, no one knew it winter would happen again...Probably a pretty busy time of year for a successful guy in the hearth biz.
We are pretty close to the stove in this room. We run a box fan in the hallway to move some air, so we don’t get overwhelmed by it.This is a very capable little stove, I’m continually impressed with it.Alright!So is the stove in your main "hangin' out" room? If so, how far are you sitting from it? You may have some nice radiation heat to look forward to. Even if you are close to the stove, like we are when in our recliners, you still don't get roasted. I can feel slight radiation off the front of the stove at my desk, 20+ feet away.
Yeah, the double glass stays pretty clean if your wood is half way dry. When you look at what they put into their stoves..double glass, cast iron parts, top or rear venting or hybrid tech on some, it's amazing that they keep their prices as low as they do.I’m amazed at how clean the glass stays, even when ran on low.
Yeah, it's not huge. I think I measured usable firebox at about 1.8 cu.ft. But if you run it like you show in your pic, with some flame in the box, the sides will start tossing heat too, not just the top as in a cat-only burn.capable little stove
The freedom bay does a good job until the temps drop. It’s in the living room in the basement, so the heat goes up stairs easily. The Princess is in the unfinished part of the basement. It does ok, it just takes forever to get the upstairs warm.Yeah, the double glass stays pretty clean if your wood is half way dry. When you look at what they put into their stoves..double glass, cast iron parts, top or rear venting or hybrid tech on some, it's amazing that they keep their prices as low as they do.
What do you do in shoulder weather, just run the Princess downstairs? Or is that even downstairs..that one pic with the stone hearth and chimney, where you had the Freedom Bay, looks like an A-frame room??
Wow, just a few hours ago I was thinking of either dragging this thread back up, or PMing you to see how the stove was doing, now that you've had more time burning it and winter finally got here. You must be clairvoyant.We just went through some pretty nasty winter weather. Wind,snow, around 0F at night, teens for a few days.This Woodstock heated the place just fine! I’m continually surprised how well the little stove does. A bigger firebox would be nice, but there’s someone here to load it mid day anyway. Lovin’ it!
