How do you like your stove? Would you get the ash pan? Any dislikes? How many square ft. are you heating? Thanks!
That's all the insight you need. Any other method of ash removal, be it an ash dump or shoveling 'em out is never going to be as easy or mess-free. Multiply that by the number of times you are going do it over the life of the stove, and deciding weather to get the ash grate becomes a no-brainer...for me, anyway. Now, some people enjoy shoveling 'em out, like the guy in the DIRECTV commercial who enjoys banging his head into the rafters.Being a total newbie I don't have any real insight into the ash pan...it's really easy and mess free to use.
He's been on an epic search. https://www.hearth.com/talk/search/48750763/Tell us about your house.
Do tell. That's an interesting observation. Were you loading the Ideal Steel E/W? Any other insights and comparisons between the 2 stoves?Yes to the ash pan. Great stove, but I actually preferred the slightly smaller Absolute Steel because it was a side loader (less ash and smoke spill, easier to load and max out the firebox volume, even though that volume was a bit less).
Indeed it will be interesting to hear branchburner's comparisons. I also need to look up his threads again on the Absolute beta test he did.Do tell. That's an interesting observation. Were you loading the Ideal Steel E/W? Any other insights and comparisons between the 2 stoves?
The PH has a little better ash pan I think, but yeah I would definitely get it on the IS. Just takes a little bit more moving the ashes around since the grate is just in the center area not the entire bottom like the PH.I have the Woodstock Progress Hybrid and I would definitely get the ash pan! It makes life so much easier when dealing with the ash.
So I purchased my stove however they did not give me my catalyst. I have been burning for about two days and I only get about 3 1/2 hours of burn. I am burning as they suggest close the bypass at 350 then shut the damper at 500. So at 3 1/2 hours I am hovering around 300° or less on the stovetop My last stove was a Sequoia and was all steel with a convection also have a catalyst but burn for about 8 to 10 hours. I was hoping and assuming that I cannot produce the heat without the catalyst???Have an Ideal Steel installed in an unfinished basement of a 3100 sq ft rambler w/ vaulted ceilings in main living area, in Western Wi. It does an excelent job heating! Does way better than I expected it would thats for sure. I use a combination of a fan blowing across the top, a fan blowing towards the stove at the bottom of the steps, and the hvac fan running on circulate cycling on and off every 1/2 hour. Keeps the temps as warm as I want them anywhere in the house and still making good heat at the 10 hour mark.
Insulation and airsealing will be key to be using it as a whole house heater though. And a good stash of dry wood also.
This is the one problem I have with these stoves. There seems to be a problem sourcing catalysts for the progress hybrid and ideal steel. I know the progress catalysts were not available for about two months this fall. Now the ideal steel catalysts are apparently out as well. In January.So I purchased my stove however they did not give me my catalyst. I have been burning for about two days and I only get about 3 1/2 hours of burn. I am burning as they suggest close the bypass at 350 then shut the damper at 500. So at 3 1/2 hours I am hovering around 300° or less on the stovetop My last stove was a Sequoia and was all steel with a convection also have a catalyst but burn for about 8 to 10 hours. I was hoping and assuming that I cannot produce the heat without the catalyst???
They sent you a new stove without the catalyst in it?So I purchased my stove however they did not give me my catalyst. I have been burning for about two days and I only get about 3 1/2 hours of burn. I am burning as they suggest close the bypass at 350 then shut the damper at 500. So at 3 1/2 hours I am hovering around 300° or less on the stovetop My last stove was a Sequoia and was all steel with a convection also have a catalyst but burn for about 8 to 10 hours. I was hoping and assuming that I cannot produce the heat without the catalyst???
I don’t think it is just Woodstock that is having issues getting them. I bought a brand new blaze king and found that it had a damaged cat. Got the dealer to order a replacement and it took about 3 weeks to get. Could be the suppliers for the cats are having a hard time keeping up.
That's good to know. I was also looking at a blaze king Ashford 30. I guess a guy needs to order the stove in spring or summer. The cats have rare earth metals on them. I wonder if that's the supply problem.
Its not going to work correctly without the cat installed.So I purchased my stove however they did not give me my catalyst. I have been burning for about two days and I only get about 3 1/2 hours of burn. I am burning as they suggest close the bypass at 350 then shut the damper at 500. So at 3 1/2 hours I am hovering around 300° or less on the stovetop My last stove was a Sequoia and was all steel with a convection also have a catalyst but burn for about 8 to 10 hours. I was hoping and assuming that I cannot produce the heat without the catalyst???
Yes. They were out of stock! It is coming Monday. Meanwhile only getting 2hrs at 500+ 2hrs at 350 and then about 300 for 2 or so. Only 6 hrs right now. Hope I can do 8-10 when that cat shows up. Any experience you have would be great!They sent you a new stove without the catalyst in it?
