I'm into my second month with my new Woodstock Keystone, and I'm loving it
I lit the stove for the first time in the second week of November for a break-in fire, and it hasn't been out since (not even any kindling used).
My question is for Keystone owners, but I think the Fireview is similar enough that I'd love feedback from Fireview owners too.
I have the whole 12+ hour overnight run all figured out, but now as the weather is getting colder, I'm wondering what setting gives the best heat output during the day, while still being somewhat conservative of wood usage (i.e. don't answer "wide open").
I know every installation is different, so please tell me about the fire, instead of the damper lever.
Example:
A - Turned as far down as possible while keeping the cat glowing
B - Turned up as much as possible, without having any flames (cat glowing very brightly)
C - Turned down so flames just disappear (really the same as B above)
D - Set so flames cycle between going out, and starting up again
E - Set so there are just barely some dark flames
F - Set so there are a small amount of lazy dark flames
G - Set so there are a fair amount of lazy dark flames
H - Set so there are some yellow flames
I - Set so there are a lot of active yellow flames
J - Wide frigg'n open (don't choose this one please)
I would also be curious what damper setting corresponds with your choice.
Thanks
Example:
Thanks
