Oak is connected, was just about to have a look at the igniter for that very reason
We will wait.
Sorry if you think I insulted people here, you read in my post that I went to Ottawa to talk to a pro maybe because I dont believe you guys here, not so, I went there to buy all that I need to go all the way up above the roof line with the proper termination cap. Instead of just selling to me, he persuaded me to lower it and try it, I'm sure it will work today but when we get a nasty NE wind again I'm worried the problem may return, hence my reason for considering going all the way up.
Starting to sound like a online tech support for some big $$$ company.We will wait.
I am not going anywhere with the forecaster being wrong and temp fell to -20Starting to sound like a online tech support for some big $$$ company.I am not going anywhere with the forecaster being wrong and temp fell to -20
Isn't it the same design as your P61A? You should have been doing similar basic cleaning on that stove on a routine basis long before now.
If it were me I would try to start the stove manually with starter gel or a torch and see if it could maintain and control the burn with its own room temp control (keep the T-Stat out of the loop until you know everything is working properly). If it can do that, it then should only be a matter of resolving why the ignitor fails to heat the pellets adequately for ignition.
I don't have an OAK and I perhaps wonder if the cold air coming in through yours may tend to cool down the heat from the ignitor, thus not building up adequate heat to allow a normal start. Can't say I've ever read of this sort of problem and maybe it isn't a problem, but maybe temporarily disconnecting the OAK might be worth a try.
I've had my XXV since 2011 and it's been a good stove. I think if you get yours up and running the way it should you'll be as happy as you are with the P61.
If your 1852 farm house is as leaky as my 1800's farm house, plenty of fresh outside air manages to find its way in. Probably the same air spaces that the mice enter through.For discussion sake I'll throw in a concern raised in my quest. The discussion of OAK for one of the stoves we're looking at, the dealer said that up here, just a bit south of canuck_22, it's so cold that using the OAK in an older home doesn't make sense. It has to heat the air up so much, thus wasting BTU's. With the temps we've had here lately, week after week of below zero, I would think that it might affect an ignitor. I would also wonder if the ignitor has a good ground contact? Much like the starter circuit on the diesel tractor or on a battery terminal? Just a thought.
I had just signed on to ask this somewhere else, but maybe this is a good place to chime in. I don't want to hijack canuck_22's problem solving though. Feel free to disregard this.
Please guys he has an OAK on his other stove and a HRV system don't go fouling up the thread.
