I am far enough ahead I only take wood when I can buck it myself. I hate odd size pieces... stack poorly, annoying to recut, can't fill the stove all the way... more trouble than they're worth.The real pain is that the electric company asked how long I wanted the rounds when they bucked the red oak. Told them sixteen to eighteen would be fine. This butt piece and most of the rest they bucked at 24". Would have had less work to do if I had bucked out the tree myself. Stove will hold 20" if ya grease the ends of the splits and use a hammer.
Bet you will next time! I've had the same experience, but it took me a few times to learn my lesson.With it laying in the yard and them volunteering to buck that big sucker, there was no way I was gonna send them on their way.
The only gripe I have with my Huskee 22-ton is that there's no choke lever, just a primer bulb. I've gotten reasonably good at starting it cold, which translates to priming, pulling, and then getting back on that primer bulb real fast with a pump every few seconds for the first half minute.Wood that has gone punky in spots was easier splitting in the extreme cold of winter - most machinery isn't fond of those temps though...
The largest three of those rounds weighed 1500 lb. each...
Ha Ha. Went through this exact exercise the other night when it was about 10 Deg out and splitter had not been started since fall. Damn I wish there was a choke on this thing. Last winter just couldn't get it started at one point and finally wrapped it in warming pad for about two days and finally got it started.The only gripe I have with my Huskee 22-ton is that there's no choke lever, just a primer bulb. I've gotten reasonably good at starting it cold, which translates to priming, pulling, and then getting back on that primer bulb real fast with a pump every few seconds for the first half minute.
