Is the auger stopping because it is not sensing a raise in exhaust temperature? The Ravelli has an exhaust probe does the Piazzetta have the same?
Have you tried a manual light with some pellets soaked in hand sanitizer or starter gel?
Smoke sensor is what you are looking for ... usually through a port on the blower or the exhaust venting. Should be able to follow the wiring from the motherboard. Beside the room probe, the only other sensor would be the 85* one which I believe corresponds to the same as my stove and resides on the hopper.
Is there the potential that all these issues are due to failure to upgrade firmware by the dealer?
What it the history of problems? Stove, dealer, or owner error? What has the dealer done to resolve them as he is the one who took the mark-up when he sold you the stove. Pacific Energy will be reluctant to talk with you as they have set up regional distribution and dealers. Have you found out who the regional distributor is from the dealer?
Need to start screaming and may be time to get a lawyer involved as these are not cheap appliances... hopefully you have a paper trail. If not start creating one. If the dealer is that uninformed and not helping, his bad rep needs to get out there too. Did he help you resolve prior issues or did you have to pay?
This is what the vac switch looks like http://www.eastcoasthearth.com/products/vacuum-pressure-switch-piazetta-pzrp-rg07070050
Should be able to confirm what software version: https://www.hearth.com/talk/threads/piazzetta-firmware-and-feedrates.119689/
https://www.hearth.com/talk/threads...aning-cycle-in-l1-and-l2.152562/#post-2048694
Apparently you may need to change out the motherboard for the software upgrade. Need to figure out what version you have... Have you had the stove on surge protection? My area in Ontario is horrible for line fluctuations...
I know there was an issue with the cast baffle removal ... remember a post of a "tool" to assist with removal.
Where in Northern Ontario? Any idea who's the next closest dealer? Wondering if the dealer was ticked that you talked to the regional distributor...
Could send a PM to Pascal Maertens to see what his thoughts are... dealer in Quebec
Chances are you won't get one ... they're locked down in the dealer's vault I'm thinking most dealer's don't get how these run because it is largely code driven from the mother board. Pascal did leave the set-up details to download on the Piazzetta sticky at the top of the pellet mill ...Right now I'm looking for a service manual and if I find one, I'll pass it along unless it's a hard copy, and in that case I can scan pages if someone needs something specific.
