I'm thinking about taking the air compressor to it then clean it with warm water with soap in it, any suggestions what might work better.
zap
zap
Which one?Mine was made out of paper. Got rid of it and bought the washable k and n filter.
If I get time tonight I will take a look at it, I think it is foam.
zap
Cool beans - it confirms my thoughts about a foam filter before the paper filter. The foam can be cleaned with soapy water - or a can of carb cleaner and an air compressor can do the trick if it is nasty.Jags, it was pouring out last night so I never did get a chance to look but Sav was nice enough to email the correct numbers.
Air Filter # 491588
Foam Pre-Cleaner # 491435
Hydraulic Filter (have) 723-0405
Spark Plug - Champion J19LM (have)
Oil - SAE 30 (Have) Advance Auto Brand made by Havoline
The above numbers are for the MTD 20 Ton H/V 1996 Woodsplitter
zap
I wouldn't run a K&N on anything I own. Had them on a couple vehicles and they always dusted the intake, which stopped after I put normal paper filters in.
The final straw was on my Jeep when I had to pull the intake off for something else and I found a bunch of SAND in it from a trip at Moab, Utah. If that filter was letting sand get by can you imagine what else was going in the engine?!!
Most small engine filters are under $10 anyhow. How often do you really need to change a splitter's filter? If it gets used 20-30hrs a year, would be fine for many years.
491588S isn't exactly a wallet buster either.
Trick with any K&N is getting it oiled right. Too little and you see dusting like you experienced, too much and it can oil your Mass Airflow Sensor, wreaking havoc. FWIW I've had several K&N products on my vehicles, past & present but I've yet to try any on a small engine.
