I just undo one of the braces to get the ladder right next to the stack. Not hard at all, for my setup. The Little Giant ladder from Costco compensates for the roof pitch.
Just remember that you need to add those stupid looking and leak causing roof braces one you exceed 4 or 5 feet of chimney above the roof. I think it's five feet but I'm not sure. And then, it will be that much harder to service the chimney cap when it's way over your head.
Nonsense. We have never had any sign of a roof leak from a properly installed roof brace. A tall unbraced stack looks more stupid, and risky.Just remember that you need to add those stupid looking and leak causing roof braces one you exceed 4 or 5 feet of chimney above the roof.
I will soon have a large supply of Ash as they begin to be killed off by the emerald ash bores.
Year three of burning an Ashford 30.1. And the third year of the smoke smell. Only on the hinge side of the door. It's like that if its 50 degrees outside or zero.
![[Hearth.com] 2017-18 Blaze King Performance Thread (Everything BK) [Hearth.com] 2017-18 Blaze King Performance Thread (Everything BK)](https://www.hearth.com/talk/data/attachments/201/201992-57a97cafbfcf218852ab44d764b8dc8b.jpg?hash=kL5psMphdD)
On my 13' 6" first year stack the stove ran great below freezing, but i wasnt going for long low burns.
Now that i am up to 15' 6" -no elbows- i can run the stove on low tsat settings at outdoor temps above freezing.
Do you know what kind of pipe and offset configuration you have that allows you to see the cap? If you can see it it must be very little of it visible.
ohiojoe13
What is your flue height, any bends and diameter?
ohiojoe13
Question: how delicate are the bypass retainers? I reloaded after coming in from a cold and rainy trick or treat this evening, and turned the thermostat to high. Ran the little ones upstairs to get them in the bath, and came back down maybe 15-20 minutes later. The firebox was roaring of course, and then I realized I never closed the bypass lever. Did I just screw the pooch?
Questions for you about your long low burns: With your Ashford 3.0 stove fully loaded and a new fire started, typically how many hours do you get from when you first close the bypass (10pm on the cat therm) until the stove has cooled enough where you can comfortably place your hand on the stove top? (since stoves continue to produce heat even after the cat goes into the "inactive" zone, I consider this a more objective test of total heat output that I can test in similar fashion...)
Related question: For your answer above, how many hours of that time does the cat thermometer remain in the "active" zone?
Thanks.
I also tried answering that post, but came to the same two conclusions. However, I can say that it is easy to have these Ashfords still putting out appreciable heat 36 hours past reload, and I know I’ve had active cat at 30 hours past reload, when running on lower settings than I normally use. I burn mostly oak and ash, but also occasionally some hickory and maple.I don't generally lay my hand on the stove top, can't answer that one.
Figuring out exactly how long (16 hours?) my cat would stay active is not something I am willing to make time for.
Thanks.
