If...Well bholler ??
I told you you'd see a difference did'nt I ??
I'm 100% sure your house was easier to heat today than it was before you hooked up the OAK...
I will report if it makes much difference
Yes it was but it is also 60 degrees outside lol. Not a good day to find out if it is doing anything.Well bholler ??
![[Hearth.com] 2018-19 Blaze King Performance Thread Part 1 (Everything BK) [Hearth.com] 2018-19 Blaze King Performance Thread Part 1 (Everything BK)](https://www.hearth.com/talk/data/attachments/236/236332-6cf5293ffb35bcfc7226cb68fc52dff6.jpg?hash=uHIkg2-pqn)
Well bholler ??
Isn't this prime BK weather? Shoulder season at XMas!Yes it was but it is also 60 degrees outside lol. Not a good day to find out if it is doing anything.
No at 60 i need no heat.Isn't this prime BK weather? Shoulder season at XMas!
Can you provide a little more information again about your setup? Any 90s, 45s etc?Folks, was encouraged to come at it again, to try and solve the smoke smell that emits from the stove… by my missus. She loves the look and form factor of the stove, a BK Princess., and she also does not want to experience defeat. Neither do I. So I put the stove back into place. And continue to try and solve the problem. As an fyi, the smoke smell is being emitted from the upper left quadrant of the door, where the hinge is located. Have no question isolated it to that specific location. I have been given some tests to perform by BK which I have performed and sent back the results. As it is Xmas and the New Years and things slow down, I felt why not come back to the forum while am awaiting BK response and… well… can’t sit idle.
To update, the smoke smell began day one of the install. The 26-27' flue had just been swept. Pristine. The stove is a demo stove. Was told it had two burns in it. I learned it was manufactured in Feb, 2018. On the original door, I replaced the gasket, and then ended up replacing the glass and then the main gasket (again). This did not resolve the smoke smell. The replacement door arrived 4 days ago and it did not resolve the smoke smell either. Same. Total of 4 gaskets have been run on the BKP. None have resolved the smoke smell. Incl a replacement door.
Couple of questions. On the replacement door from Blaze King. My two questions are… is a latch replacement from Hechlers the correct place to order a replacement latch? I know it is, but am asking because I had an odd comment about another BK replacement part from Hechlers that did not instill confidence in Hechlers. Anyway, the latch on the replacement door is loose, by a wide margin. Defective. So it no question needs replacing. And yes, in spite of the loose latch.. I have manually placed ample pressure on the replacement door to see if that would create a successful seal and stop the smoke smell. It did not. So am not confident a replacement latch will solve this still. Regardless, it needs to be replaced.
Second, am awaiting communication from BK on what next but thought to ask… anyone know of a way to create a tighter seal, as in move the door closer to the stove opening? I.E. adjusting the door closer to the stove? Will of course follow what BK advises, but thought why not ask here for opinion while I await the next communication with BK. Wondering if the door is seating too far away from the stove opening. Misaligned?? tx
Just one has a little basement but not like living space, just storage. No it is not common here to see houses with basements. They are not very tight except additions over the years. Some, a good part of the houses are Adobe.I don't think they have basements in NM, do they? Why so many stoves, are they huge houses, not very tight, or what?
also is the knife edge on the stove centering on the door gasket material?Did you do a dollar bill test?
@aaronk25 came up with a theory that with a tall chimney and high draft, air flow from the air wash may be altered causing smoke to be pushed against the upper area of the door and smoke could escape there.was encouraged to come at it again, to try and solve the smoke smell that emits from the stove
Yessir... dollar bill test from the first day of the install. And several times since.
Hard to believe that wouldn't just burn up...if he was ever able to get a fire going, that is.did you check to see if your wife stuffed a rag in the chimney like the other fellow who was having issues?
Rookie mistake, I guess. Rule #1: If the smoke isn't being pulled up the chimney, check the chimney.that sure is a strange one isn't it?
