What happened......?Spilled milk. Just forget it ever happened.
Nothing.What happened......?
I must be rusty, but I threw my bypass and let it cruise for about 10 mins with the door cracked open![]()
How high did the probe spike?
it was well active, beyond 12:00 for sure.
If your wood is dry, just get enough of it burning to get the stove temp high enough so that the cat will light off soon after you close the bypass, as evidenced by the cat probe temp rising fairly quickly up further into the active zone.Yesterday morning, quite a bit of smoke was seen at the chimney top, while the stove was in this state.
In the evening after reload, the stove top was as high as 700, but after calming down, the fire held thru the night.
I kind of get the idea that all the wood in the box should be hot and ready to burn when the thermostat gets turned down. But the immense flaming makes things very, very hot.
That's kind of what my intuition told me, but the Mrs. was sure we had to leave it "engulfed in flames for 20 minutes" as the manual states. Maybe those extra minutes are to drive off any excess moisture in the wood?If your wood is dry, just get enough of it burning to get the stove temp high enough so that the cat will light off soon after you close the bypass, as evidenced by the cat probe temp rising fairly quickly up further into the active zone.
How long has your wood been split and stacked in the wind? How many rows stacked next to each other? Top-covered?
Our new BK Princess insert seems to run the thermometer completely beyond the Active range. And then it seems impossible to bring it back, whether turning the thermostat to low or leaving it at medium.
Through all of this, we are diligently following the directions in the manual. Temps have dropped to mid 30s outside, while the house was mid 60s in the AM.
Does all of this seem normal enough? I've been heating with wood for many years, and these prescription fires are not the same as the constant tinkering that I'm used to doing.
Is the stove designed only for very cold outside temps and always gonna be a pain to use in the shoulder season?
Thanks in advance for any advice.
So you’re seeing smoke out of the hi money while the combustor is pegged beyond active, but where is your air control set when this happens? Where was the air control set prior to this? It’s not clear if this is happening when air is wide open, just after turning down, or after an extended period at lower burn setting.Our new BK Princess insert seems to run the thermometer completely beyond the Active range. And then it seems impossible to bring it back, whether turning the thermostat to low or leaving it at medium.
... If the wood is dry enough, can I just build a campfire and shut the bypass when it's hot enough?
Are the fans on?I just fired up our new Ashford insert for the first time a week ago and a second time this week. I have a question about using the cat. I activate the cat when its in the active zone but I am noticing if I turn the heat output down to like med/low in a few hours it drops out of the active zone. Is it ok to do this overnight?
Fair enough, and for the record I typically (for the few times per year my BK needs to be lit) stick a quarter super cedar smack in the middle of a full load. Ha.Hey Nigel,
I’m not going to say top down is bad, I really haven’t experimented with them to make any such conclusion. But I’ve put more loads thru my BK’s than any three average wood burners, and I’ve never had to resort to building a top-down fire to get one going, I’ve just always used the traditional (“bottom-up”?) method outlined in the manual.
If top down has any advantage, it’s likely beyond the scope of this new user’s issue, or at least that’s what I suspect.
Are the fans on?
no not cold enough for them yet, I am breaking the stove in during the shoulder months taking advantage of the cooler weather
Turn it up a little higher until you find “your” minimum setting for the conditions that keeps the cat active.
How long is the chimney from connection to insert to cap?no not cold enough for them yet, I am breaking the stove in during the shoulder months taking advantage of the cooler weather
Find the lowest setting for your combination of stove-chimney (cat still active, always!) this requires a bit of experimentationgot it. what do you do about overnight then? I'm thinking the stove overnight cant make it a whole 7 hours without dipping out of the active zone. Although I haven't really had a chance to play with that yet I have only done 2 fires in it
I’ve not run an Ashford 25, but I’ve put about 40 cord thru a pair of Ashford 30’s over the last 4 years, and I have no issues making it 7 hours on all but the absolute highest settings.got it. what do you do about overnight then? I'm thinking the stove overnight cant make it a whole 7 hours without dipping out of the active zone. Although I haven't really had a chance to play with that yet I have only done 2 fires in it
about 23'How long is the chimney from connection to insert to cap?
But with a BK one only needs to start the fire once a year in fall, right? Then it's on to reloading every day and a half. If so, then many less starts.Hey Nigel,
Plenty...don't turn down thermostat too rapidly. That can cause a rich air/fuel ratio. The manual provides this guidance.about 23'
I still suggest top down ideally tho
I'm a big top-down fan. Cleanest start you can do, since the smoke from the wood that is catching fire is being consumed by the flames above. And I think you're right that having the flame in the top of the stove will get the cat/upper stove hotter, quicker and allow light-off sooner, while getting less wood gassing. All of this works only if you have dry wood.If his wood is super super dry, getting the cat up to temp asap is a priority, in order to avoid the "bowels of hell" as described by Highbeam. Top down could help with that I was thinking.
Like these guys said, once you establish your minimum air setting, your cat will keep eating the smoke until the wood is down to coals and there is no more smoke. This could be longer than 7 hrs or shorter, depending how much wood you loaded.I'm thinking the stove overnight cant make it a whole 7 hours without dipping out of the active zone. Although I haven't really had a chance to play with that yet I have only done 2 fires in it
