Did you install the stoppers for Santa's sleigh, or were they already there?![]()
Snow cleats for those who may not know. Keeps the snow and ice from sliding down and piling up on the gutters or from avalanching down the roof and damaging the landscaping or structures below.
Generally, most soft woods. Some people keep some soft wood (pine, fir, etc.) set aside just for this purpose.Not sure if this is the right place for me to ask this?
As I continue the learning curve with my bk king. Question? What wood doesn’t produce many coals? Im noticing that when it’s time to clean ashes it’d be much easier if I burned a load of wood that wasn’t so “coal forming” Im burning mainly ash. Im in indiana so midwest hardwoods mainly. I was thinking cherry?
The term “rake” applied to this tool is likely confusing. Here’s the implement I use:
I always just set it and forgot it with my noncats as well. I don't understand why so many think noncats take constant attention.We call that chasing the dragon here, we as with the BK you can set it and forget it.. please excuse my dry humor.
It depends how they are burnt but yes there is typically more creosote buildup in the firebox of a cat stove than a noncatDo cat stoves end up black inside? My defiant had a nice creo costing, but my firebrick stays pretty clean in both of my stoves. The Morso gets a nice coating of fluffy light creo and fly ash, nothing crusty or goey, on pretty much every surface after the firebox. My cooker is basically the same. It all comes off with a wipe and then vacuumed out.
Wow that's a lot of snowguardsIt was just getting light when I left the house this morning, after a fresh reload on one of the stoves. Checked the plume and it was clear! This was 10 minutes after turning down to cruise setting, after the usual 20 minutes on high.
I also got a shot with both chimneys, the one on the left was 10 hours into a 24 hour burn cycle, the one on the right was 30 minutes into a 12-hour burn cycle.
I should do more maintenance in scraping crusty creo off the inside of the box when I get a chance to let the stove go out. This should also have the added benefit of allowing radiant flame heat to get the stove up to temp faster, and allowing more heat to transfer through into the room when cruising.
Do cat stoves end up black inside? My defiant had a nice creo coating, but my firebrick stays pretty clean in both of my stoves. The Morso gets a nice coating of fluffy light creo and fly ash, nothing crusty or gooey
Yikes, three cups caked crusty, crispy creo crud carved from combustion chamber!It depends how they are burnt but yes there is typically more creosote buildup in the firebox of a cat stove than a noncat
 ![[Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK) [Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK)](https://www.hearth.com/talk/data/attachments/253/253521-8f8346aea5178c12db2d4da06e033d6e.jpg?hash=jG-DK5mLMH)
I believe he's talking about the greater fluctuation in room temp that you have with a non-cat, with his "chasing the dragon" or "chasing the heat curve" comments..I always just set it and forgot it with my noncats as well. I don't understand why so many think noncats take constant attention.
I find hardwoods coal up a lot more than softwoods when burning in our stove. One of the reasons I like to burn doug fir is complete burn and low ash afterward.Generally, most soft woods. Some people keep some soft wood (pine, fir, etc.) set aside just for this purpose.
Weird question, but what are the dimensions of the end part of your ash rake/hoe? My cook stove did not come with a scraper and I bought a piece of flat steel from the hardware store since nobody nearby has such a product. An ash rake would perfect for the long skinny morso and cleaning out the cooker if it's short enough.
This is Doug fir in my noncat. It makes coals but they’re hot and burn down to almost nothing.I find hardwoods coal up a lot more than softwoods when burning in our stove. One of the reasons I like to burn doug fir is complete burn and low ash afterward.
![[Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK) [Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK)](https://www.hearth.com/talk/data/attachments/253/253535-c870b6f7cac7301bbdaf705cc5bcb897.jpg?hash=-GXf49ay1S)
Good thing you're bald!I almost burnt my eyelashes taking this photo!
![[Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK) [Hearth.com] 2019-20 Blaze King Performance Thread Part 1 (Everything BK)](https://www.hearth.com/talk/data/attachments/253/253548-51c3b740e38bcebe0d84fa3f052b2c9c.jpg?hash=VKljzavW7e)
I know when I would run my non cat in the living room I was always fiddling with the air control, not wanting the stove to take off and go nuclear, but at the same time give the wood load a chance to catch properly so I could have the cleanest burn as possible with the given tech. Then there were the times the stove would bake us out of the living room.. but that was purely a setup issue and not the stoves fault.I always just set it and forgot it with my noncats as well. I don't understand why so many think noncats take constant attention.
