Not good
Please tell more
 I guess you forgot..
			What is this minor talk about BK and rust?
			my door is starting to show signs it’s time to give that gasket some attention, so I guess I’ll be learning about it this summer.
I have 30+ cords thru that stove as of today, in five burn seasons, in case you wanted an idea on how long they can be ignored.
Yikes, six cords a year, in just one stove?
 How many cords, total, do you go through??
I'd check that bypass gasket while you're doing the door, maybe some of your heat is going up the chimney. I seem to remember you talking about smoke from the flue.
I was guilty of "ignore-ance" also, wrt the bypass gasket. I finally replaced mine after nine years. It still seemed to be sealing OK with a dollar test, but apparently old gaskets just leak more. I definitely noticed a hotter stove top over the cat, after gasket replacement, 50 degrees or so.
Manual recommends this cement.. (broken link removed to https://mid-mountain.com/wp-content/uploads/datasheets/Thermoseal%201000SF%20Cement.pdf)
			now I realize the tech changes quickly enough, and all of the working parts and gaskets take enough abuse over the course of a decade or two of full-time burning, that I’ve changed my perspective. Stoves are consumable...Use them 15 years, and then replace them with something far better.  Building an expensive and weighty tank with a shell that will vastly outlast the working components within, or their relevance with regard to current emissions targets, is not likely the best path for any manufacturer trying to compete in a market with any cost sensitivity.
I don't agree; Everything other than the stove body is pretty much replaceable on wood stoves.
			there may be stoves out there with thicker shells than my BKs, but I don’t think I care.  They generally don’t perform as well as the BK today, and will almost surely fall even shorter in comparison to the new ca.2030 BKs with which I’ll replace these, after fifteen years of full-time use and 150 cords thru the pair
Standards pretty much didn't change in 30 years, until 2020. The stoves still haven't made any major breakthroughs, so I think your assumption that magic is going to happen by the time you need a new stove, may be a bit optimistic.
I also don't think you have enough stove experience in your house to be able to proclaim that other stoves "generally don’t perform as well as the BK today." The 2020 stoves are all pretty much showing similar efficiencies, etc, to previous stoves.
Seems to me that you have stoves that are efficient at "low and slow," but you don't live in that type of house.
			I cannot see my BK lasting another 10 years, but I hope both of yours do.
Mine has worked pretty hard although the F600 burns about a third of the 10 cords that I usually burn,
I will probably be changing it for something else unless BK fixes this one for me,
I'm not sure my insurance would want me to weld it up myself
webby, you're shop is outstanding to give that kind of service on a stove that old,
as is blaze king, hope my dealer is as well.
Heck yeah, if you get a free repair, great, keep ridin' it. It's a PIA to pull the stove, but what the heck..
Even if you have to weld it, that ain't too big a deal, and the insurance man will be none the wiser.
			I'm not bad mouthing blaze king or the stove
I'll try to sum up where I'm coming from wrt to BK. I get accused of being a "hater."  Not true; It's just that I'm not a "lover" like some that are either newbs, or came from an old smoke-blower stove or a cheap secondary burn stove. Or a tricky stove like Ashful's Jotul 12.
It wasn't long after I first started coming here that I started seeing the BK posts. Right away, my hackles went up. I knew enough about physics to know that there's no free lunch, and that all the talk at that time about "long burns because of the magic fairy pixie moon dust sprinkled on at the plant" was a load of crap. Then I saw that it was just a plate-steel stove, read the list of other problems that had arisen over the years, and wondered how people were calling it a quality stove that justified the premium price they ask.
"Cost sensitivity"..??
 A thermostat isn't going to tip the scales for me. No, I've never burned a BK, but if I see one, or if I were to burn one, I'm pretty sure I'd come to similar conclusions that I now have. I
could be wrong but I doubt it.
Hey, there just
aren't any perfect stoves. My stove has cemented seams, which can leak air. I had an air leak on my new Ks that gradually got worse and I had to eventually patch it. Probably will get to the point in 15-20 years where patching will be a stop-gap measure, and it will need a tear-down, to some extent. Soapstone doesn't rust though, so I expect more than 6-15 years.
I'm really inclined to go with a simple non-cat at this point, after seeing how my SIL's T5 runs. No bypass gasket, no cat, easy sweep, etc. But it would have to rear-vent into a masonry fireplace, which severely limits my options at this point. I might have to look at the feasibility of raising the lintel in my fireplace..
			We will be approaching that volume with the T6 by the next season.
With nothin' but a door gasket, I bet.
			You guys are putting a lot of splits through your stoves..... labour intensives
I guess you got a tight house? How many cords/year?
			Starting to wonder about the bypass gasket too.....stove is still perfectly serviceable and has proven to fit my application very well.
The new princess would be a fine replacement with better emissions numbers for 2020. Like an 85% reduction somehow.
Yeah, just slap in a new bypass gasket; Made a difference here..
Pull some bricks while you're at it, and report back.
Nobody's yet gotten to the bottom of how they reduced emissions that much, have they? I haven't seen any comments here..
