2025 severe weather
Sometimes I fantasize about a heated driveway that clears itself.
I have a big Ariens snowblower, but I don't like to blow wet snow. I would have, but it was a windy day. I'm kicking myself in the butt now.
I got it cleared, but was running out of juice.
Dang, thats' colder than a witch's t!t.
Yeah, thankfully these cold snaps are always short lived. I'd say we hit 0 about 2-3 times a year. Where I grew up, 40 miles northwest of here and 500ft higher elevation, we would routinely see temps below 0 degrees in the winter.
One of those cold nights my buddy had stayed late video gaming and learned the hard way what the "W" in 10W30 stands for. Didn't get his car started until 2pm the next day.
I lived probably about 50-60? miles south west of there in Cornwall, CT. Zero degree days were not too common. The coldest I remember was -15ºF one year. My Volvo wouldn't start. The local garage suggested lighting a fire under the crankcase! I stoked up the wood cookstove instead and waited a couple days for it to pass.
I've heard people talk about lighting a fire under their car but never seen anyone actually do it. That's a good way to enter yourself for the Darwin awards.
Reactions: Burnin Since 1991
It is 9:15 now, and the outside air temp is -21.4 ::C
The reported wind chill (real feel is -34.3 ::C
Coldest night of this fall. Not winter yet.
We also have 12 CM of snow on the ground
and more to come on the weekend
Yes, he was an old timer. That might work with a model T and gravity fed gas, but not with the fuel pump down low on the engine block.
10*F right now (1:45 am). Supposed to get down to about 3*F. Then Monday, into negative territory.
Later in the season, it is not uncommon to hit -18*F several times (although last time that happened was several years ago). I have had years where the high didn't get out of single digits for a couple of weeks.
Here's what I woke up to in my kitchen. I guess I need to set the clock ect.
Heat pumps on, but turned down as low as they will go which is 16C.
The one in the living room was blowing a bit of hot air. It is almost new.
My other one is not even trying which is good as it is old does not work good on heat.
It does seem to cool OK, so I hope it keeps going.
The pellet stove ran all night perfectly. Didn't use too many pellets. I had the
house circulation fan on low. The new AC Infinity blower works way better than my old blower.
I also replaced 3 windows this spring and that is making a huge difference.
Edit - I did have electric heat on too maybe set at 18C. They were not working hard, maybe 1 bar out of 5
Edit 2 - Just found out some people had no power all night ! Stratford (sister city to Charlottetown) no power.
and many more north of there. I sure hope they had a plan to keep warm.
Dec 05 2025 08:45 AMTotal Customers Out: 5637
[td]MessageLong[/td]
  • [Hearth.com] 2025 severe weather
I quite like doing the snow removal on the driveway between the old 90's quad/blade and big old Ariens blower (12 36). Problem is it rarely snows at the right time where work doesn't interfere and there is almost always someone who has driven over it, wet snow, or rain that has followed the snow. Seems it could almost always be a few degrees cooler...
Our driveway is over 300 yards with parking for maybe 12 near the house, super rewarding, especially when the snow is just right, deep and cooperating. Which is almost never...
I added a couple Amazon led lights powered off a tool battery to the blower, that sure helps.
ok, you goy my attention. I've been looking to do something like that with my Ariens. I want to try and find something I can usb charge and that I can use on the blower. Hmmm picked my interest
Reactions: bogieb
Mine has the headlight as it was a "Deluxe Model". Also heated grips. Might be able to add the light as an option.
One thing that would work is a USB rechargeable headband light. I have a bike light that is rechargeable too.
10x brighter than the OEM one that is still hooked up. 2x 15w
Thanks guys, I ordered a 2 pack of magnetic lights. Not sure if the magnets are strong enough to deal with the amount of vibration of a blower. If not I've got two more LEDs on hand to use if the power goes out or as work lights. I will check back once I get them.
Monday night says hold my beer and watch this!
My neighbour years ago put a hubcap full of bbq briquettes under his F150, had an old sleeping bag over the top of the engine compartment. He placed the hubcap between the rad and the front of the engine so it wasn’t under the oil pan that was leaking.
That same cold snap my FIL was using a 10’ downspout with a 90* elbow at one end and a tiger torch at the other. My job was to slide under the vehicle ensuring the elbow discharge wasn’t under any oil leaks and not directly under the oil pan, he spread an old canvas tarp over the engine to trap the heat. The biggest challenge was to keep everything lined up, as the heat was melting the snow under the downspout.
Both methods worked and no vehicles burnt to the ground.
One of those cold snaps that nighttime temperatures were in the -40C warming to -30C daytime.
Things should be a real mess around here on Wednesday, a forecast of 0.36 of an inch of rain with the snow. The driveway should be like a skating rink again, good thing I never took the 3 point sander off.
I'll be getting 8 bags of tube sand before Wednesday gets here.
With the unseasonably warm weather we have also gotten a lot of rain in the region causing record flooding. The rain being supplemented by large scale snowmelt in the mountains. Creeks that are usually tame and 20 ft across have turned into raging torrents and the rivers that they flow into have swollen incredibly. Whole communities have been evacuated due to flooding. The rivers have crested now, but unfortunately, heavy rains will return soon in some areas. We are grateful to be on higher ground that drains very well.
It looks like temperatures will be dropping towards the end of next week and along with that the snow levels. Hope that helps sequester some much needed snowpack.
