Craftsman 18" 42cc saw. I've taken to sharpening the chains myself and I'm guessing I'm doing a poor job of it. When making a cut the saw will curve to the left as I cut downward into the wood...I'm guessing that since the chain isn't just popping off the bar that the bar is not the problem. I've using a hand file with a visual guide, but no jig type sharpener. Its the right file for my application according the chain info (I forget the size, but I know its the right one). The process I'm using is to start from the master link and go through the entire set of teeth in one direction, same number of swipes from the file in one direction only, flip the saw around and do the teeth in the other direction, same number of strokes, doing my best to keep even pressure.
So what am I doing wrong? Should I scrap the file and get a jig based one so my angle is more consistent? How do I know which side teeth are the problem?
