For a long time I have known that when I have an oil filled space heater running on "medium" in the family room two of the other outlets on the circuit in the room get warm. Thought it was normal. Last night I was doing the annual test of heating with just the oil filleds in the house on a cold night.
I walked over to those two outlets and they were HOT. I grabbed the IR thermo and one of them was 107 degrees. This is an outlet on an outside wall on a 20 degree night. I unplugged the heater from the other outlet on the circuit. 30 minutes later the suspicious outlet was still at a hundred degrees. I popped the breaker on the circuit and contemplated a bit and went to bed.
This morning I pulled the hottest outlet. It was a "backstabbed" install where the wires are punched down into the back rather that attached with the screws on the sides. As obviously all of the outlets in the place are. A little visit to Google produced the info that the things are notorious for overheating and causing fires due to poor connections. I replaced that outlet and now it has been 55 degrees all day.
A good idea would be to use that IR gun that is so much fun to use to check the wood stove temp to check the outlets in your house. These were installed 30 years ago this month and heaven only knows how long that one has been getting ready to make us homeless.
