I have had the stove of death for 3 years now. I've got it running smoothly and non-smoky with a few minor mods and burn habits. But, alas, it won't run more than 3 hours then fuel must be added to the glowing coal bed.
Here's what I'm tinkering on, making it into a long burn cat(in flue) stove. To do this, my idea is to build a spring loaded adjuster over top of the 2 open holes in the door. It has no primary air adjustment so controlling the air through those holes seems to slow down the burn but makes it a dirty burn as the secondaries tend to stop burning when that happens. So I will add the flue catalytic combustor, with a temp guage to monitor exit temps on the cat. I have 8 feet of single wall inside the room that I hope will harvest a lot of the heat off the cat. And hopefully the cat will clean up a slow burn and keep the pipes clean.
Now please analyze what I'm doing and offer productive ideas, not "buy a good stove" or "that stove is junk". I find it a challenge to make something that's less than ideal, useable and reliable.
What say you!?
What say you!?
