When my installer put in my Napoleon NPS-40, he said I didn't need the air intake piped to outside the house. Now that it's getting chillier and I've used it some, I wonder if it's the right move.
Intake from within the house seemed smart to me -- the fire is burning with 68 degree air. I'm now pumping air from inside to outside the house. That inside air must be replaced to even the air pressure. So now the pressure outside the house is greater than inside, forcing cold air in through any leaks I have. As I'm buttoning up the house more, I can imagine that whenever I open the door a blast of cold air is going to be sucked in.
With an intake from outside, the fire will be burning with zero degree air. But there won't be any pressure difference inside and outside the house, and would reduce infiltration.
What do you think?
What do you think?
I went to the auto parts store and got 1.75" aluminum flex tubing for $6. I found out my fireplace insert had a fresh air channel in it and is hooked up to the outside, so I tapped onto that.
