Alderlea T6 first fire
Morgandad56
9
Hartford, CT
Hey guys. First fire this morning for my new PE Alderlea T6. Doing a couple small burns to break her in. It was 40 this morning here in CT. Will get a burn tomorrow morning. Love the looks of this stove. Looking forward to this winter!
  • [Hearth.com] Alderlea T6 first fire
Just how it was taken. Very flat.
Stove holds the heat for quite a long time after it’s out.
I noticed this from the first overnight fire. The even heat made a big difference in reducing room temp swing when compared to the F400 it replaced.
Reactions: Highbeam
Same here. I like I can put 2 pieces in at 7am, 2 more at 2, then load it at night and house is not boiling. It was a high of 55 the other day with lows in the 30s. House stayed between 74-78. This is with the damper closed within 10 min of adding wood. This stove will crank the heat if you need it.
Air control was closed or flue damper?
Regarding the top of the stove, there's space between the corners of the top plate and their supports.
That's not right,.I think
Reactions: begreen
Yes, particularly on the left side. There is an adjustment on each swing out trivet wing to level them. It would have been nice for the dealer to have done this.
Huh, I’ll have to check that out in the morning when the stove is cooler. She is fired up right now getting prepared for the cold blast lol. I love this stove. My 3600 sw ft, long narrow house is so much warmer this winter. No fuel oil is awesome! Longest overnight burn and still able to rake coals forward and take off was 11 hrs. Very pleased
We're in for a cold spell. I fired up the T6 this afternoon.
That used to be our routine but this has been an unusually warm fall.
Air control....I have a 16’ straight pipe up, and I use room air no outside
The T5 is drawing so hard on 16' that I stacked two flue dampers to slow it down a bit when needed. She doesn't have a problem with it going over 800* most of the time. If you position a stove top meter near the flue exit, you can see it through the slatted top with a flashlight.
I'm not sure how close to 11 hrs. she could get, packing the 2 cu.ft. box, but I think probably pretty close with some decent wood like Red Oak or hard Maple. She has enough coals to restart the next morning, with a partial load the night before.
T5 almost stuffed to the max with seasoned red and white oak. I’ll probably reload in 10 hours and have plenty of coals. We have the storm coming tomorrow in NH so I’ll be burning all day.
So last night the pipe damper was about 90% closed. I think the air was also about 90% closed. It was a cool 20 degree night with well seasoned wood and with a full firebox you need to be careful not to overfire.
Anyways pics are the pipe damper setting, coals and temps after 10 hours.
The pipe temp maxed out at 900 and the stove top was probably 700 but I can’t remember but like I said you have to watch out for overfire.
When it's gets quite cold and draft is extra strong, I can close the air off completely and close the flue damper. That settles in for the long burn with a SST of around 550º and probe stove pipe temp around 600-625º. The stove top temp will continue to rise for a couple hours while the flue temp slowly decreases. At some point they are equal.
Reactions: Itslay90
That's very impressive. And in a good looking stove with a great fire view.
Reactions: Enplater
Hey I just put the pipe damper back in my pipe, where should I put the pipe thermometer after the damper or before it ?
Condar says no less than 12" above the stove top. I'd think that once you have the flue damper set, the temp will pretty much equalize above and below the damper, but I'm not sure.
I have mine above the damper.
About 6" after the damper. Make sure the probe doesn't interfere with the damper operation.
