BrotherBart said:
				steam man said:
			I have a hard time believing anyone can use an electric water heater for $30-50/month.
With everything including the well pump in this house being electric and our bill never being over $79 when the A/C is off I would have a hard time believing that the 50 gallon electric water heater is using more than $30 a month in electricity. The 14 cents a KWH number I quoted is the average total bill with taxes and everything else divided by the total KWH usage. And our bill is within a few bucks a month of the average bill for customers of our electric co-op.
There are only two of us here but we are here 24/7/365 and I run my business out of the joint. With a whole bunch of computer horsepower running 16 to 17 yours a day.
I cannot see any way that having a boiler fire up every time you use some hot water can be economical.
My electric bill is never below $120.00/month and that is low. Typically it is around $140.00+. I also have a gas dryer/cooktop and heat/DHW comes from oil. I also use my woodstove to supply DHW in the winter. Flourescent lights too. No AC. I also have teenagers use a large amount of hot water, a number of computers and tvs, etc. In other words, all the things I can't control.  The average house can use 30-60% of its total heating cost for DHW. My single elderly mom uses next to nothing in hot water so in the real world there are alot of variables to consider such as hot water use, initial investment, and payback. Like I noted, at about 12 cents/KW seems to be the break point for oil vs electricity but I also don't see electrical rates staying that low. I just watched an electrical generating representative say so on tv. Bottom line is that by the time power companies generate electricity and get it to your home, it is the least efficient method of heating.
Let's do the numbers-The maximum recommended hot water usage for a 2 bathroom home is 140 gallons/day. (I looked it up). Multiply that by 8.34lbs/gal to get 1167 lbs. 1 lb of water needs 1 BTU to raise 1 deg F. So to raise 140 gallons of water say from 50 - 120 deg F, you would need to multilpy 1167lbs x 70 = 81690 BTU's needed. There are 3413 btu's/KWH. 81690btu's/3413=24 kwh/day. Multiply that by 30 and you get 720 kwh/month. At $.14/kwh that is equal to $100.80 monthly bill. At my $.18/kwh for me that would be $129.60.
Do the same for oil assuming $5.00 gal at 85% efficient appliance and 140,000btu/gal. 81690 btu's/day x 30 = 2450700 btu's/month.  2450700btu's/119000 btu's/gal (at 85% efficient) = 20.6 gal heating oil. X $5.00gal = $103.00 total.
The last I paid was probably about $4.60 so my bill would have been about $95.00. Of course my bill doesn't include electricity to run the boiler but it isn't too much.
How much DHW do you get for $30.00/month? $30.00/.14 = 214 kwh. 3413btu/kwh x 214 = 730382 btu's. 730382btu's/70 deg rise for 1 lb of water = 10434 lbs/water. Divide that by 8.34lbs/gal = 1251 gals hot water. Divide that by 140 max gallons/day and that equals just about 9 days worth of hot water at max design usage. Divide it by 30 and you will have about 42 gallons/day.
I have seen numbers saying that the average house uses 20 gallons day/person. That seems low to me. I don't know how much you use but my whirlpool bath alone can use 30-40 gallons.
Less than .6 gallon oil/day for DHW. That's still not bad. I am still going solar.
If anyone wants to correct my numbers, feel free. I used 140 gallons/day from a plumbers design handbook. Of course less useage will change the outlook somewhat. Right about now my brain is overheating.
